Question about Intel Computers & Internet
PC TAKING CUT OFF AT UNSCHEDULE TIMING BUT GREEN LIGHT OF CPU ON
Intel P4 915 GVSR chipset motherboard taking cut off but green light of pc is on.
  • 4 Answers
Re assambel ur cpu
pick out ur pro , ram and battery cell from motherboar and clean ur pro fan properly with air. and re insert all after 5 mint
and then start ur pc then it is ok
if not then chk without ram on ur pc is it beep if yes then clean ram and re insert it then start if not then change ram moduel with new one.
Posted on Jul 03, 2009
Intel d845gvad2,Motherboard getting on green light is coming but without ram board does not giving any beeps and processor fan and smps fan are running but does not giving any display,then which one may be...
you can try taking out CMOS battery from the board and try to reset BIOS jumper on the board. once you can also try removing and reconnecting the CPU Fan and CPU from the board.
All the best
Jun 08, 2011 | Intel Desktop Board D845GVAD2 Motherboard
Fans work green light shows on motherboard but cpu wont power up
Any HDD light on / if not could be failed HDD OR faulty IDE / Sata cable.
Did you get posting beep if not remove / replace ram / reboot.
If you did then either mobo / CPU may be faulty.
May 10, 2010 | Intel D845GVSR Motherboard
Changed the CPU fan and now the monitor won't turn on. Power light stays green, and harddrive light stays yellow. Fan is running.
its not problem of fan. re-insert your ram. even if doesnt come then problem with ur motherboard chipset. if in blore call 9972888885
Jan 21, 2010 | Compaq Presario S6000CL (DT072A) PC...
My cpu flash a green light in the back, and the pc wont cut on. took it to the shop and they disconnet the mother board and connet it back it work. i took it home and connet up my pc up and it wont cut on...
Since you brought it to the shop before. I would recommend you call them first and tell them it is not working once you brought it home and can you bring it back for them to test again. Also it is a good idea to turn on and off once or twice before taking it back to make sure it works
May 06, 2009 | HP Compaq FS7600 17" CRT Monitor
I have a emachine PC. PowerSupply blew up. changed it still down
Dear,
ELECTRIC SHOK OR IMPROPER EARTHING IS DAMAGE POWER SUPPLY,MOTHERBOARD,PROCESSOR,RAM
HOW TO CHECK IT.
(WHEN CHECKING KEEP CAUTION :- REMOVE HARD DISK DRIVE POWER SUPPLY SOCKET)
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Monitor not coming ON
The monitor is not able to detect any video signal from the motherboard, that means your pc is not starting up. Try cleaning the RAM first. Then clear the CMOS and try to start ur computer again
Nov 24, 2008 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Booting Problems 845 GVSR Chipset Motherboard
it is possible to repair,just check the rate if it is costly then you better take a new one
May 15, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Still motherboard green light
Hay harjeet83, that green light you see by the CPU is just letting you know there is power to the board. Unfortunately Intel does not give up much information regarding the 915 Chipset. The other things I can suggest are to look at the capacitors on the board. See if any show deformation usually located at the top of the capacitors. You can enter the bios & check the hardware monitor.
Hardware monitor will show the temp of the CPU, motherboard & speed of the CPU fan. Some user’s have the fan speed set too high for the CPU, like 1200rpm & the bios will shut down the PC. If you’re memory gets too hot you’re system can shut down.
In the end if none of the others I mentioned seem fine than swapping out the PSU can not hurt. Keep in mind there is very little support for the 915 chipset.
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1765&lang=eng
Mike
Apr 10, 2008 | Intel Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Computers & Internet Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
