Question about Acer Aspire 8920-6048 Notebook
Aspire 8920 D Drive broken
My D Drive is broken.
Every time I turn my laptop on i get a that my drive is damaged and that in the future I may loose everything that's on it.
I tried couple of times to format it with cluster size 4096 bytes. But it crash each time, or I believe it does.. Because after a whole day, it's still not finished
Can anyone give me a solution?
Acer Aspire AX1300-E1820A will not turn on. even if hot wired, I didnot back up my files Help please
Worst case scenario: extract the hard drive from the Aspire (usually its just 2 tiny screws holding
the HDD), and plug this PCMCIA-bus drive into another (functional) laptop. Windows will
mount the drive (but not load the OS). Extract the files using the functional PC's operating system.
In future, always back up your files, or even better - keep no files on the laptop at all - do this
by storing ALL your files to a flash drive. That way, the system can crash an any time (and they do),
and you lose nothing.
Mar 28, 2011 | Acer Computers & Internet
My acer aspire 3680 could not power on by bat and adaptor
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 08, 2010 | Acer Aspire 3680 Laptop
Acer 5570z will not boot up or turn on
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
DC Jack diagnosis:
Sep 26, 2010 | Acer Aspire 5570-2067 Notebook
Laptop freezing
replace the hard drive and clean out the fan
or just go buy a new hp and put you laptop on craigslist
Mar 27, 2010 | Acer Aspire 8920-6671 Notebook
I cant use my dvd drive, i cant see on my computer???
usually even if the dvd was broken it would still show in my computer.
so try turning the computer off and turn it upside down. look to see if any screws came loose in the area of the drive. gently push the drive in the sleeve in case the connection came loose. restart your computer in safe mode (click f8 as you power on your computer) go to my computer and check
Dec 25, 2009 | Acer Aspire 5536-5224 Notebook
Key popped off on my acer aspire 8920
most of the time your better off buying a new keyboard or just not worrying about it
Nov 10, 2009 | Acer Aspire 8920-6671 Notebook
Dvd drive does not open
Have you tried pushing a paperclip in the manual release hole in the bezel of the drive? The opening mechanism of the tray may be jambed shut, possibly pushing the release will unjamb the mechanism.
Oct 06, 2009 | Acer Aspire 8920-6048 Notebook
Acre aspire 5100
sounds like a loose hard drive connection, or you need a BIOS update. You should check Acer's website for an updated BIOS. You should also remove the hard drive (usually a 2 minute job with a small screw driver) and re-seat the drive.
May 20, 2009 | Acer Aspire 5100 Notebook
Recovering acer aspire 8920 from drive d - how
During boot up press the f10 key, that should take you into the system restore. This will most likely erase all of your data so make sure it is backed up.
Hope this helps
May 02, 2009 | Acer Aspire 8920-6048 Notebook
Region setting on Acer Aspire 8920
Older DVD drives use RPC-1 firmware, which means the drive allows DVDs from any region to play. Newer drives use RPC-2 firmware, which enforces the DVD region coding at the hardware level. These drives can often be reflashed with hacked or Australia and New Zealand (hardware region coding prohibited by law in these countries) RPC-1 firmware, effectively making the drive region-free. However, this usually voids the warranty and can render the drive inoperable if something goes wrong... better contact your laptop manufacturer regarding this
Sep 26, 2008 | Acer Aspire 8920-6048 Notebook
Acer Aspire 8920-6048 Notebook Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
