The Christmas Cactus is supposed to droop ,as it falls over the side of the pot, not to much water, also a small amount of feed nearest the time of flowering Oct/Nov, you can prune if you must, but just be patient, why prune the roots? As i mentioned not to much water dont forget its a Cactus.
How does a Christmas cactus know when to bloom?
Care of Christmas Cactus in Bloom. Christmas cactus plants should continue receiving dark, cool treatment for at least 6-8 weeks, or until buds begin forming. Once buds have formed, it usually takes up to 12 weeks (or less) for blooms to appear. The plant should also be relocated at this time.29 Jan 2015
use some spray root killer wait for then spray root kill on them for 5 day then wait for the to die if roots are on top of ground were you can see them cut in out with milwakie recipricating saw you cut all the root sticking out of the ground through away
Like an other welding job - be sure the grounds are clean and secure. Ground as close to cut as practical and if trying to cut painted area - remove paint for good ground and to cut down on fumes from burning/melting paint. Disconnect battery as well so as not to bachfeed any voltage into your electrical system. IE ecm - computer
find the hot or live wire and leave that alone then twist the rest together and touch them to the hot wire till it starts then remove the hot wire away from others and be sure not to let it ground out after that if the rest of the wires are together light and speedo should work
