Question about GE Heating & Cooling
Cental air unit stopped working, I replaced the capacitor which had blown apart, but the unit does not restart. It works when I push in and hold the button on what I believe is the relay where the power comes into the panel of the unit. Is there another fuse or reset button that needs to be reset within the unit. Any suggestions? The model # is AC1BN036-A and it's from about 1995.
  • jpstanto Jul 02, 2009
    I just replaced the capacitor, so I don't think that is the issue. The fan blade rotates freely. Both the fan motor and compressor motors come on and run when I push the what I believe is a button on the relay.
    Do you know of any other resets that would normally need to be checked on an outdoor central air unit?
    Yes, the link did not help.
  • 1,800 Answers
You shud test the relay with multimeter for any shorting out or restricions.
locate it and test it, if it is not beeping or showing zero its defective and you gotta replace that relay if its good, well you gotta locate the shorting out in the IC of the main board.
Posted on Jul 02, 2009
    President:
  • 942 Answers
Hi
Every air conditioner is equipped with at least two motors, the compressor and the fan motor. It is possible for the fan motor to be defective and the compressor to be running. If this is the case the unit will appear to be running and may even sound "normal" but no air is blowing out the front or back of the unit. If, after removing the cover of the unit you discover the fan blade is very stiff and difficult to rotate, the fan motor should be replaced. If the fan blade turns freely the circuit powering the fan motor will require electrical troubleshooting. It will be necessary to have a qualified technician locate the cause of the problem, which may be either a problem with the capacitor, the selector switch or the motor itself.
i will give you a site that can help you to troubleshot.
http://www.repairclinic.com/0088_16_1.asp#Level1_7
Goodluck!!!
Regards
PCmania
  • Neciforo Llanto Jul 02, 2009
    did you try to visit the link that i can give you, just click it in you can find the way how to troubleshot your aircon
    http://www.repairclinic.com/0088_16_1.as...
    Goddluck!!
    Regards
    PCmania
Rudd air conditioner outside fan won't start
I just had the same problem. I replaced the motor with no luck. It turned out to be a bad capacitor. If it is a dual capacitor, three prongs on top, it also starts the compressor. It is recommended to replace the capacitor anytime you replace a motor. I would try replacing the capacitor first. It is a lot cheaper that a new motor. If that does not fix the problem then you can get a motor. No harm, no foul. The slow start of the motor is a common symptom of a bad capacitor. The motor is not getting enough voltage. The capacitor increases the voltage like a transformer. It will boost it to almost 400 volts, depending on your unit.
Jun 21, 2012 | Heating & Cooling
I need a manuel showing me how to hook back up my fan to capacitor after i took it apart.Forgot how to wire it back.Where can I find a manuel to download.wiring.
*CAUTION*
Capacitors hold a large electrical charge and will discharge upon contact with your skin. This is enough to stop your heart and cause death. If you are not confident of your abilities around these devices then please leave any testing or repairs to a professional.
*Rant off*
Most air conditioners, and all electrically operated equipment, will have a wiring diagram written somewhere inside of the unit. Usually they are a printed piece of paper pasted on the inside of the cover or on the rear of the unit. You don't state what kind of system you are working on so I cannot be more specific than that.
On split systems, or central air systems, the two brown wires from the fan go to the capacitor but yours may be different.
Jun 16, 2011 | Heating & Cooling
On cool will work for a short time. then will stop regardless of room temperature. If stopped for a short while then restarted will begin to spit water or ice.
Unit stopped by coil sensor when ice formed.
Problem due to weak capacitor of indoor fan motor/short of gas/coil & air filter dust blocked.
Replace fan capacitor/if short of gas, tap up some gas/clean coil and air filter.
Hope, it's helpful.
Feb 26, 2011 | Mitsubishi Heating & Cooling
Problem with Vulcan Powerhouse 145 cental heating unit.
You should have a high limit switch possible on the bloiwer compartment may be man reset or just bad you do not say how old unit is I would temp jump out high limit to test operation then replace asap
Jun 11, 2010 | Broan-NuTone 9965 Coil / Ribbon Heater
My crate amp stopped working
If you overvoltaged it and the fuse is not blown, i would check for blown capacitors. Capacitors are supposed to have a flat top. If its blown it will have a domed top or have junk leaking out of it. Best to replace with same voltage and capacitance, though some can be replaced with different stuff... if you know the circuit :D. You can find capacitors on line pretty cheap.
Don't know what a capacitor is or unsure what a blown one looks like? Type "blown cap" into google image search. You will see a bunch of healthy and blown caps, Mylar and electrolytic style on the first page of results.
Dec 27, 2009 | Audio Players & Recorders
HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 06, 2009 | Dometic Rooftop RV Air Conditioner
Outdoor unit will not run
this sounds like a bad t stat if you are pushing in the contactor for the condenser outside if that is not it let me no where your contacter is
Jan 08, 2009 | Heating & Cooling
Heating & Cooling Logo
126 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
