Question about Maytag Dryers
Loud rumbling noise when dryer starts up - Maytag Dryers
  • williamcote Jul 02, 2009
    Thanks, will replace roller wheels
  • 158 Answers
There is a roller going out in the dryer that holds the drum in place.
Posted on Jul 02, 2009
Loud rumbling noise when clothes are added to samsung dryer
the problem can be found at the loading capacity of your dryer, too much load can result to dryer to sag thus the contact between the drum and the sides can cause the rumbling sound.
Dec 07, 2013 | Dryers
My dryer has been fine until last night when it started making a loud rumbling noise as its running. Any ideas about it?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 28, 2011 | Dryers
Noise in operation. A loud rumbling noise when
Any noise must be identified with a good observation of the point of noise source.
This can be done with a good view with all safety precaution while the unit moves. Use good lighting and make sure that you are not putting your hands into any moving parts while the set works.
Now disconnect after observation and manually turn the drum, the motor and the rotor to fix the point of noise. this can be a faulty bearing assembly or a faulty suspension all of which will require a resetting/reassembly.
Feb 17, 2011 | Whirlpool LER4634J Electric Dryer
I get a rather loud rumbling sound when I first start up the dryer the drum is turning but still getting the rumbling sound but not as loud.
Sounds like you need rear rollers or you have a bad blower wheel. If you turn the dryer off and still hear the rumble for a few seconds its the blower wheel. If the rumbling stops instantly then you have bad rear rollers. Hope this helps.
_MJ_
Dec 14, 2010 | Maytag Dryers
Ge dptg750ec make loud rumbling noise after replacing blower
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 09, 2009 | GE Profile Harmony DPGT750EC Electric...
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
Kenmore elite3 dryer rumbling noise
there are two rollers that hold up the drum...they go bad...and are ez to replace! they are sold in sets of two for about $30.00
Mar 15, 2009 | Kenmore Elite HE4 Electric Dryer
Loud Noise when drying....
hi thanks for the question tome iot sounds like the blower a rumbling noise and the dryer takes too long to dry so i would check that thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
101 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
