Question about HP LaserJet 1220 Printer
HP 1220 will not print blacks
Works normally but will not print black, new cartage, run test ... any document with black text only will be blank.
have used it on mac and pc in past, now will not print the black on ether.
    Problem Solver:
  • 19 Answers
I see you repalce the cartridge already, with being the case you have 1 of three things goijng on.
1. Laser is failing.
2. High Voltage Power Supply is fialing or
3. Transfer roller is bad.
You will need to seek professional assitance to determint which one.
Posted on Jul 07, 2009
Black ink ran out, replaced it with new brother cartage and now it only print part of the text
Run a cleaning cycle on the print head through your printer utility. Then run a check nozzle test to verify if the nozzles are cleaned. Use only denatured alcohol and a Q-Tip to manually clean the cartridge holder & orifice.
Mar 26, 2017 | Brother Office Equipment & Supplies
My HP 1280 printer does print black and white text
Could it just be that the black cartridge has run out? If not, try and clean the print heads. You should be able to do this in the printer options in Windows. It is more than likle that the black nozzle is blocked.
Dec 13, 2009 | HP DeskJet 1280 InkJet Printer
Check print cartridge error
Set the properties to print on HP paper. This usually solves the problems
Mar 09, 2009 | HP DeskJet 3745 Printer
The Printer is not sensing the Black Cartage
if their cartridge worked and yours did not. buy a new cartridge.
Jan 27, 2009 | HP Officejet Pro K5300 Laser Printer
Black blocked by magenta
One ovbious option would be to have a friend print it out.
I assume that is not an option.
Some printers just won't let you print if a single color is out. Yes, stupid. Try printing a blank page. If it fails, there is no other option but to replace the cartridge or print elsewhere.
If the blank page test works, this next option/test is worth a try...
Depending on the app you are using, you can specify the color breakdown of the colors you are using. In your case, it is possible that the text is set to a rich black (4-color) rather than just black.
If that is the case, to test this most quickly, make a new file, and create a new black (black2), set to 100 black, 0% other colors.
Type a wor and set it to print in that color and try to print it.
If that works, apply the same technique to your real document.
Hope it works. I've been stuck in the same situation, and some printers will just not let you print if a single color is out.
Good luck.
DigiChick
Jun 09, 2008 | HP Color LaserJet 2600n Printer
Colors print, but not the black!
that same thing happen to me try to wipe the needle that the ink is on with baby wipes.
Nov 27, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
Eadch line of text is slightly faded at the bottom from laserjet 1100
It is possible that the transfer roller needs replacing as this causes it. Have you recently wiped clean the black roller that sits under the toner cartridge if you have you may have damaged it.
Best thing is to replace the transfer roller very easy to do and not expensive.
Hope this works for you and please rate me
Thanks J
Oct 11, 2007 | HP LaserJet 1100 Printer
Empty ms word printout
Hi, You can try: 1. go to Start, Printer and Faxes, right click on your 3745, click on Properties, Printing Preference; 2. Check to see if you have any Advanced tab or button; 3. Check if you can set the printer to text only; 4. Check if you can set the printer to use black ink only. 5. In MS Word, verify through the use of Print Preview that your document is as you would want to be printed; 6. In some instances you may have to set manually text color in MS Word. While your document is open, click Ctrl + A to select all, then choose font color to "Black". Alternately, in your MS Word, you can click on "Format", "Font", "Font Color" set to "Black" rather than "Automatic" and set this as the "Default" setting. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | HP DeskJet 3740 InkJet Printer
HP LaserJet 1220 Printer Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
