Question about Acer Aspire 5500 5570-2609 Laptop
Bluetooth always disconected
Re: bluetooth always disconected - Acer Aspire 5500 5570-2609 Laptop PC Laptops
Restore the phone.
Posted on Dec 04, 2011
  • 1,006 Answers
Witch cellphone do u have???Go to the options on bluetoth on phone and select there FIND ME OR MY PHONE'S VISIBILITY
Posted on Nov 09, 2007
0 characters
3 Points
I want to connect pc suite for nokia through bluetooth
if you laptop not have a bluetooth adapter buy one compatible usb bluetooth and ready can you conect all bluetooth diveces please vote
Aug 29, 2012 | Dell XPS M1210 Notebook
How do I transfer photos from my folder (in my phone) & phone to either my sim cad or computer
If your computer has a bluetooth device installed in it, and your phone also has a bluetooth device installed in it, simply turn them on and, If you want to send files (photos inclusive) from your computer to your phone, right click on the file (photo) you wish to send, click on send via bluetooth, search for your phone but make sure your phone's bluetooth is turned on. When you find your phone on the list of available devices on your computer, select it and if the computer asks for a pass code, give it any number, like (1), and it will send the pic to your phone. If you wish to send files from your phone to your computer, go to the bluetooth icon on the navigation area of your computer, click on it and select receive a file, then your computer is now ready to receive files and you can now send the photos from your phone to your computer. On the other hand, if there is no bluetooth device installed on any of the devices, you can use the USB cord that came with your phone. Connect it to your computer, it would first of all try to install the device driver software. After then you can send files from your phone to your computer and from your computer to your phone.
Jul 10, 2011 | Samsung PC Laptops
My laptop not access bluetooth device plz send my a guide line i conect my bluetooth device
are you using the right driver? download the latest driver from its website, it's free! Then pair them again (passkey is four zeroes - 000)
Aug 16, 2010 | Acer TravelMate 2300 Notebook
Acer laptop cannot conect to handphone.
Check in your device manager to see if your bluetooth device is enabled. Also check in the Bios settings and in your power management to see if there are any settings there for the bluetooth.
If there are no entries for bluetooth in device manager, you may need to buy a USB bluetooth adapter. I know that some models of Acer laptops are bluetooth capable, but do not have the internal bluetooth adapter.
Jan 15, 2010 | Acer PC Laptops
How do i use the bluetooth facility in Acer Aspire 4715Z? What are the steps to be followed for enabling it? I would like to transfer data to and from my fone via bluetooth..i have a sony ericcson K790i...
just turn on the wifi or bluetooth switch in both device. after select the data which you want to send,right click > send > via bluetooth > search device > select the device > next > give pass word.. eg.0. > next> send>
in mobile you can see accept option. just select it,give pass word that you will give in your computer... eg.0 > and accept.
Mar 17, 2009 | PC Laptops
How do I get bluetooth
turn on your bluetooth on your phone. then turn on blutooth on your PC. serch for bluetooth devices using your phone or PC, once it finds the other device, click on it to pair them together, usually it will ask for a password, use 0000 on both devices ( you can use any password, as long as its the same on both devices ) it will tell you that the two devices are now paired. now select the song you want to send to your phone right click on it and select "send to" then choose bluetooth device. accept file on your phone and it should send it.
let me know if that helped ?
Jan 03, 2009 | Acer Aspire 5315 Notebook
I can't use my lap bloutooth
just switch on the bluetooth first thru button located on the left side it will light up blue color then see the small icon on the right corner of taksbar right click and Open bluetooth settings and then select options tab and then check the allow the bluetooth devices to find this computer check box and then come out selecting OK
now try to send some file from phone or pda thru the sending option and then search the bluetooth devices in ur device u will see ur pc in the list just select do the pairing first use code 0 zero to pairup both devices put zero on both sides and then conection will be established now u can easily send data from both devices thru bluetooth
pls let me know if it helps or u have some other problem of switching on the bluetooth device that means software issue or driver let me know i can help more in this
pls rate me FIXYA for my help if u like
Dec 30, 2008 | Acer Aspire 4720 Notebook
Bluetooth dongle
  1. Go to the file you want to send to the phone
  2. Right click the file and select send to option
  3. Unde the sent to option select the bluetooth option
  4. Undet the bluetooth option select your mobile phone if it is listed or choose other if it is not listed
  5. Follow the process that pops up in the window until you send the data to your phone , make sure your bluetooth is activated on the phone and when it ask you to pair device you so perfectly
As an alternative method (though no a easy method)
  1. Move or copy the files you want to sent to the phone to the bluetooth exchange folder
  2. access your computer from the my devices option on your phone and choose the get it option to get the files coppied to your phone.
Mar 25, 2008 | PC Laptops
Bluetooth conection
you have to activate blue tooth connectivity on your phone
Dec 02, 2007 | Toshiba Tecra A8-S8514 Notebook
Bluetooth conection
Make sure You have a Bluetooth device on your laptop[of course that is necessary].Now i recommend you to use WIDCOM bluetooth software.It is theeee best for bluetooth device handling.
Also make sure that the bluetooth device on your samsung blackjack is working.That can be done by asking your friend having a bluetooth enable phone to search for your mobile via bluetooth,be sure you turn on your bluetooth device on your mobile and make it visible to others.
Make sure after intalling the software (WIDCOM) the drivers are successfully intalled.Then pair it with your mobile.So simple isn't it
Please rate me my name is Karatela
Dec 01, 2007 | Toshiba Satellite A105 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
102 people viewed this question
Top Acer PC Laptops Experts
Brian Sullivan
Brian Sullivan
Henk de Ruiter
Henk de Ruiter
Are you an Acer PC Laptop Expert? Answer questions, earn points and help others
