Thank you for your question, Friend.
It sounds like the temperature control of your Frigidaire freezer (FKFH21F7HW) is possibly in the off position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try reactivating your freezer by pressing the UP arrow until display shows "4" or desired setting. Please allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting.
If this is not the case and your freezer has no power, can you please elaborate prior to your problem any other symptoms? For instance, did notice any error codes, or other strange functions? Also, may I have your model number please? The serial tag, which lists your model number, is normally located inside the cabinet on the left/right side wall. Thank you and I look forward to hearing from you. - Z
