Question about Hayward H400idpl2 400,000 Btu Low Nox Heater Propane
Makes a loud bang when starting
The heater makes a loud bang when trying to start and it may do this one or two times and then start. we have lots of wasps could they have built a nest? the heater acts as if a pocket of gas may build up could the heating tube have a crack in it? thank you--- john
  • 990 Answers
You will need to pull your tray from the heater to check for Wasp nests or other problems. You need to be careful with the wasps if you smoke them out be very careful not to burn any wires or components on the heater. If you have access to a co2 fire extinguisher the cold and lack of oxigen will hold them at bay for a few minutes. Back to the heater...
Your dead on about the gas build up. This comes from something blocking your pilot so that your burner flame isn't lighting on the burner that is connected to the pilot. If you have a wasp nest on the burner this will do be the problem. I want to think that when the heater fires this would fix that problem. What is more common is on the gas pipe that feeds the burners you have a gas orface for each burner. Small spiders will sometimes build webs that resemble lint inside the orfaces. You can clean these with a bent wire.Other than that anything blocking the burners will be evedent. I hope this helps, good luck.
Posted on Dec 10, 2009
After my heater fires I hear a loud bang a see flames shooting out the blower. The heater keeps working but happens every time it starts up. why?
Sounds like something happened with gas pressure?
Way high?
Absolutely, call somebody / a tech that knows how to test for gas pressures using a Manometer. Your Gas provider, should have a tech service dept.
Jun 18, 2015 | Pentair Mastertemp Heater
Why does Miele w2515 makes loud banging noise when it is about to spin?
See if you can level out the unit. Sound like the case is responding to un-even pressures.
May 23, 2014 | Washing Machines
Banging boiler
How to remove the air from your boiler heater The boiler is probably air bound, and the system needs to be purged of air. The link is for an informative video. It will explain the various parts/ produdures to purge the system.
Bleeding Hot Water Boiler
Apr 09, 2014 | Washing Machines
Loud noise filling water
Probably heat trap nipples, or other constriction in pipes.
http://waterheatertimer.org/New-water-heater-making-noise.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment and say what you find
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 24, 2013 | Water Heaters
Rinnai heater 403FT. The heater works but the flame goes out and comes back on with a loud bang as if there is a build up of gas
I suggest you call for service. This "bang" could be a serious problem in the future - meaning the next time it tries to start.
Gary
Jul 04, 2011 | Rinnai Heating & Cooling
Very loud wall heater (bang!!) heat up and cool down.
cozy heat exchangers do tend to make a lil more noise than avg. if its popping before the blower comes on its proubly the heat exchanger expanding. you would have to watch the exchanger while it was heating to see exactly what is causing the noise. but as a renter you should try reporting it to the landlord first and try to get a tech there before digging yourself
Mar 15, 2009 | Cozy (W352E) Heater
When you start printing it starts making loud banging noises
It's called an ENCODER STRIP you will have to revmove the covers to reinstall.
Jan 02, 2009 | Dell 924 All-in-One InkJet Printer
Steamer
If the machine also did not work again, you have blown an internal fuse or the boiler heater has failed. If lots of steam came from inside the machine when it went bang, you have probably blown a hose, or a safety valve blew off because the heater failed to regulate temperature. Good luck, Saeco are expensive people!
Dec 21, 2007 | Saeco Vienna SuperAutomatica Coffee...
Hayward H400idpl2 400,000 Btu Low Nox Heater Propane Logo
241 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
