I have a new laptop but I con't find the settings of the wireless linksys g2. Is there anything I can do to match the two?
  • 909 Answers
Use the wireless network wizard, in the start, control panel network and internet connections, wireless network setuo wizard. As long as you know the security code to log on to your router, should be ok.
Posted on Jul 02, 2009
My wireless router stopped working. If I bypass the router, I have Internet. The error message says "wireless security types do not match. I have a linksys wireless g broadband router.
wireless security type is the encryption setting you are using.
you either need to change it to wpa/wpa2 mix or wpa.
make sure the client(laptop) is set for wpa or wpa2.
Feb 26, 2011 | Linksys Wireless-G Broadband Router
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
We have a new laptop, and desktop and a linksys
by default all laptop has wilreless adapter inbuilt in it
but desktop doesnot have wireless adapter
if you have wireless adapter on all laptop and desktop
in that case
reconfigure wireless setting of router
changed ssid and network key
regards
prakash
Mar 14, 2010 | Linksys Computers & Internet
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Connecting new linksys n to our brother mfc685cw wireless printer. Printer will not read new linksys n router
For isolation purposes, you may want to test the printer through the Linksys router via Ethernet cable and see if you can print if it is wired to the router. From there, configure the wireless printer to match the settings on your Linksys router. Once done, try printing again wirelessly.
Tips:
1. Make sure that they are on the same LAN segment. By default the IP address of the Linksys router is 192.168.1.1. so you may want to configure your printer using 192.168.1.2 for them to communicate.
2. Make sure that the wireless settings on the Linksys router match the wireless settings on your wireless printer. Check the SSID/Wireless Network Name and Wireless Security. All wireless settings should be the same for them to communicate wirelessly.
Jul 12, 2009 | Linksys WRT160N Wireless Router
The setting on my laptop for the linksys do not match the requirements of the linksys
Make sure it does;
If Automatic Configuration DHCP is enabled on the router your PC wireless or ethernet TCP/IP properties should also be set to "Obtain TCP/IP address automatically" and "Obtain DNS server address automatically".
If your security is set to WEP your PC wireless network or ethernet connection properties should also to be set to the same authentication type.
Jan 18, 2009 | Arris Wireless G Broadband Router (wr850g)
CAN'T cONNECT
You must set up the security settings that are in the laptop to match the settings in the router. These may be WEP, WAP, MAC address filtering or others. To change the settings in the router, you would used the web based interface. If you need more info:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859761879&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=6187945678B11
Oct 24, 2008 | Linksys Wireless-G WRT54GS Router...
No network
The Wireless Security of the router doesn't match your laptop's wireless settings. Make sure you configure the wireless security password correctly on the laptop. If you don't know your wireless password, try these steps:
-Connect your laptop hard wired to the router.
-Open Internet Explorer and on the Address Bard type http://192.168.1.1 press enter.
-It will prompt you for username and password. By default, there's no username and on the password type admin and hit OK. If admin didn't work, type your own password for the router.
-When you get to the Setup page, click on Wireless Tab, then click the sub-tab Wireless Security.
-Look for Security Mode. If Security Mode is WPA-Personal, the Passphrase is the wireless security key that you need to enter on the laptop's wireless settings. If the Security Mode is WEP, the WEP Key 1 is your wireless security key. Connect to the wireless network and type it in. That should solve your wireless connection problem.
Sep 06, 2008 | Linksys Wireless-N WRT150N Router
Wireless problems with windows vista
You just need to remove the preferred networks on your vista, follow this.
Right click the wireless icon>network and sharing center>manage wireless network>remove all preferred networks.click OK.
Then connect again to your network that should solve it.
Jun 13, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
