Question about HP StorageWorks Media Vault Pro mv2040 (GJ422AA#ABA) 500 GB Network Storage Server
Low gearbox oil frontera v6 automatic
Can someone send me a diagram of the underside pointing to where the top up plug is on the gearbox ie dip fonger to test level as there is no dipstick
How to check gear box oil in a automatic vauxhall frontera
Posted on Aug 08, 2009
Would like to know where the top up plug for my gear oil is and if there is a dip stick manual proton savvy bt 2006
Manual Transmissions don't have dip sticks.
2. Manual gearboxes have a drain and filler plug. The filler plug is usually found in an accessible position on one side of the gearbox which has to be accessed from under the vehicle.
To top up the gearbox the car has to be perfectly level so if you need to add oil to the gearbox you ideally need to get the car up on a garage hoist/lift so you can both access the filler plug easily, remove it and pump in the fresh gear oil. The usual correct oil level on these gearboxes is level with the bottom section of the filler plug opening in the gearbox. However you should check with the proton service staff on the correct procedure for topping up the manual gearbox in your car.
Mar 20, 2016 | Proton Cars & Trucks
How to check the engine oil level and what kind of oil do i use if low
In the diagram #2 is the oil dip stick for checking oil level. Recommended for your car is 5W-20 oil. 56754356-a8ab-4cde-aad0-fba4600f8e3b.jpg
Sep 07, 2014 | 2005 Lincoln LS V6
Low oil level in the gearbox
How do you know this?
If you have an Automatic (dip stick), top it up.
If you have a manual I can only guess you have an oil slick under the car. If so, filling it is a temporary solution as you must find the leak.
To top up the manual transmission you need a very large allen head wrench (like 19mm or so) to undo the fill plug on the side of the transmission.
Get a pump for the oil (GL-4, I believe) and fill until it is dripping out the fill hole (with car level). Once it stops dripping out fill hole, replace plug.
Jan 26, 2014 | 1986 Volkswagen Wagon Camper
I have a 1994 Isuzu Rodeo that I've just bought. I cannot find the transmission dip stick. Where is it located?
Most transmissions didnt have a dip stick. There is a drain plug in the trans pan and another plug higher up in the pan which is the filler plug. Fill until oil trickles out, put plug in loosely, then start and run through gears. Remove fill plug and top up level while engine still running and make shure vehicle is on flat surface when topping up level until oil trickles out fill plug again.
see some similar posts on Jackaroo, Trooper, Rodeo, Frontera all had similar set up, similar trans.
Jul 11, 2011 | Isuzu Rodeo Cars & Trucks
Kia sedona automatic transmission gearbox
To fill the transmission fluid, you need a funnel that fits into the dipstick tube, add fluid there. If the fluid is black and smells burnt, that's bad. I would have the fluid changed. These transmissions don't have a filter, probally a bad idea.
May 03, 2010 | 2003 Kia Sedona
Irt leaks reddish oil
This is transmission fluid. If it leaks between the motor and the transmission, the seal for the torque converter is probably leaking. If you have transmission cooler lines, check to see if there is a loose connection. The oil can run down the outside of the line and drip at the lowest point.
Oct 23, 2009 | 2004 Chrysler Voyager
Location of Automatic Transmission dip stick on BMW Z3
it wont be a dip stick as such it will be a single bolt on the side of the gearbox remove this then top up the gearbox until the oil starts weeping out of this hole wait for it to stop leaking then replace the bolt job done!
Jun 23, 2009 | 2001 BMW Z3
Auto gearbox
if it has a dip stick under the bonnet you need to have the engine running with the box in neutral then dip the oil
if the engine is warm then it should read around the top mark, if the engine us cold then it should rear around the lower mark
if there is no dip stick then there is no way of checking the level and you will need to drain the box and re fill with the correct ammount through the gearbox breather on the top
Jun 07, 2009 | Peugeot 405 Cars & Trucks
Auto gearbox service/oil change renault espace 3.0l automatic
if its working leave well alone,its a renault remember,topping up is done via the auto dip stick ,draining is done by slackening off the sump pan
Dec 31, 2008 | 2003 Renault 181
HP StorageWorks Media Vault Pro mv2040 (GJ422AA#ABA) 500 GB Network Storage Server Logo
740 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
