I am trying to find a usb charger for my phone - rectangle 5 pins top and 5 pins bottom
  • dennis_long9 Jul 02, 2009
    The phone is unbranded, from China or Hong Kong.
    Pocket PDA.
    Inside has S108 and IMEI 135790246811220.
    The port that plugs in to the phone is 6mm wide 2mm deep and the length that plugs in to the phone is 5mm.
    The local phone shop does not recognise it, so I dont think this is a common usb lead.
  • 630 Answers
Sounds like a miniUSB but without specifying the make and model of the phoone it's a pure guess.
Posted on Jul 02, 2009
Battery problem
follow this test and fix it. God bless you
Bad cable connection
Check the USB cable for damage and dirt, especially at the ends. Then try using the wall charger, as this will provide greater power input than the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect the 30-pin dock connector at the bottom of the iPhone for dirt, lint, and damaged pins. Clean out the dock connector very carefully with a tooth pick or soft toothbrush. If the dock connector is broken, you will have to replace it.
Nov 06, 2013 | LG Cell Phones
Iphone wont charge
follow this steps and fix it. God bless you
Jul 31, 2013 | Apple iPhone 3G
Samsung gt 55830 is not charging the battreies
follow the instruction and fix it. God bless you
Jul 27, 2013 | Samsung Cell Phones
Telefunken mr701 diagram
Jul 11, 2013 | Cell Phones
Turn off audible alarm when changing towers
God bless you
Jun 01, 2013 | HTC Cell Phones
MX46-633V CONNECTING FRONT USB
I believe you're referring to the AOpen MX46-533V
The Front Panel USB header is Blue in color, and located in-between the white No.3 PCI expansion slot, and bottom edge of the motherboard;
http://www.ebay.com/itm/AOpen-Model-MX46-533V-Socket-478-Desktop-System-Motherboard-/130774572519?pt=Motherboards&hash=item1e72c59de7
With the motherboard in the installed position;
5 pins across the Top row, 4 pins across the Bottom row.
Pins across the Top row are numbered EVEN
Pins across the Bottom row are numbered ODD
Starting on the Left side coming across to the Right, Top row;
Pins 2, 4, 6, 8, and 10
Bottom row;
Pins 1, 3, 5, and 7
There are TWO USB connectors supported off of this USB front panel header.
For one of the USB front panel connectors;
A) Pin 1 is USB PWR 0
Goes to the VCC contact pin on the USB connector.
B) Pin 3 is USB_FP_P0-
Goes to the D- pin on the USB connector.
(Data - )
C) Pin 5 is USB_FP_P0+
Goes to the D+ pin on the USB connector
(Data +)
D) Pin 7 is Ground (GND)
Goes to the Ground (GND) pin on the USB connector
E) No pin 9
F) Pin 2 is USB PWR 0
For the other Front Panel USB connector;
A) Pin 2 is USB PWR 0
Goes to the VCC pin on the USB connector
B) Pin 4 is USB_FP_P1-
C) Pin 6 is USB FP P1+
D) Pin 8 is GND
E) Pin 8 is USB_FP_OC0
Leave unconnected
This is more information on a standard USB connector pinout,
http://en.wikipedia.org/wiki/USB
( A USB connector, and a USB plug are not wired the same.
The plug is wired backwards from what a connector is.
Otherwise you would have power and signal going to the wrong pins, and burn the USB Front Panel header out on the motherboard )
AOpen MX46-533V motherboard manual, but it is in Japanese.
May be one in English out there.
The Front Panel header pinout, USB header pinout, etc, is easily cross identified,
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Manual / Japanese manual for MX46533V / Japanese / 1/28/2006
Go to the far right, and click on the Floppy Drive icon above -
3701.1 KB
On the next page click on the mirror server website that is closest to your country.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country server name it may take up to 30 seconds, before the first page comes up.
(File is downloading in background)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 19, 2012 | ASUS P5PE-VM Motherboard
Nokia 6120c not charge
Basic steps to do is :
* check or try another charger to see if that is the problem.
* also check or try another battery,this might be long time and over use.
DIY Procedure
In doing this method,here's how :
1. remove the hausing or front cover by lifting up the side clips (you can use your thumbnail inserting the sides of it)
2. Using a T6 precision screw driver, unscrew the 6 sides
3. gently lift up the entire module from the back cover or housing. (start from the top to lift it up.)
4. now locate the charging pin at the bottom were the charger seems to be connected.
5. check the charging pin if it's clean or in level (the 2 metal pins),you can use lighter fluid or any solution that cleans the parts as long as if its dry after.
6. also check the board interface align on the charging pin it if's also clean.
7. now assemble the phone and then try to charge it.
Hope this solution helps...
Jun 14, 2011 | Nokia 6120 classic Cellular Phone
I put a motherboard in my pc and i dont know where 2 put POWER SW,RESET SW,HDD LED,POWER LED....please help
http://eu.shuttle.com/archive/en/prod/mb/big/av49vn.jpg
ok man on this picture in the bottom of the pic there will be a sort of black rectangle with nine pins, 5 on bottom, four on top. This is where all your POWER SW,RESET SW,HDD LED,POWER LED will be plugged in. I could not find instructions for your board but for mine it is
Looking at the pins from the side where there are 5 pins on the bottom and 4 on top. The top two sould be the power led the two next to that should be the power switch, the bottom two to the left should be the hard drive led and the two next to that should be reset.
This is not the guaranteed position seeing as we have two completely different models.
Hope this helps.
Jun 17, 2009 | Ultra Computers & Internet
Charging
USB and wall chargers use different pins on the phone. This tells me one of your pins if dirty or the wall charger is fried.
  1. Take a toothpick or brush and scrub the contacts on the bottom of the phone
  2. Inspect the phone and charger pins for dirt / debris
  3. Try charging again
If this does not work, try your charger with another phone (if available). You can also take it into any cell store to test it.
Nov 22, 2008 | Sony Ericsson w580i Cellular Phone
LG VX9800; Phone powers off when removed from ANY Charger
I noticed this same issue with a phone I acquired... I would look in the plug at the 'bottom' of the phone, the charging/data port.
Most of the time the pins move a bit in normal use, and if the second to the right (with the keypad facing up) pin on the phone's port has moved, or (in my case) touched other pins/grounded out, that was the issue.
I have seen this on a few phones now... It was the plug, or the charger 'worn' out on the plug, causing mis-contact with the pins!
-Cheers
Jun 25, 2008 | LG VX9800 Cellular Phone
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
