Question about Haier HWR12XCB Air conditioner
A.C . makes a buzzing noise...
..and will not blow air or stay on. It sounds as though it could be the blower or motor, perhaps? The buzz is loud at first then reduces to a faint hum.
I have a 3-year old Haier 12,000 BTU window unit, bought new.
Since I didn't pay much for it, at Walmart, is it worth repairing with those costs?
  • 82 Answers
If you can make repairs yourself a motor is only about $40 and a capacitor about $10. Either could be the problem. If you have to pay someone to do it buy a new one.
Posted on Jul 02, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Dec 13, 2013 | Precor C956i Treadmills with HR /...
My 2000 cavalier makes a space ship sound when driveing (inside), cant hear anything outside though?
I don't know what a spaceship sounds like lol... but check for this ...
Paper might have fallen down in one of the vents causing a buzzing where the fan motor is blowing. Sometimes switching the heat up and down and blower motor faster and slower can dislodge the offending item.
Another possiblity is that the rubber piece where your steering wheel goes through the firewall to the motor compartment may have come loose. Lay on your back with seat pushed as far back as possible and inspect and adjust the rubber noise barrier.
Look for kids toys that might have got jammed down by the seats.
If you need more help, please describe what else might make a similar noise to help pinpoint the type of noise. Use words like whistle, chirp, squeak, buzz, etc...
Feb 09, 2011 | 2000 Chevrolet Cavalier
HEAT PUMP
It is not normal to have a loud buzz associated with the electric heat. Try turning the heat off and running the fan only to see if the buzz continues. The buzz could be coming from any number of sources including an electrical component, the blower wheel, a loose fastener...etc.
The temporary smoke and smell could have been the dust burning off the element if the elements have not been used in a long time. However, if the elements have been running, it could be something got loose in your system and stuck between the blower and the heating elements.....for example, the wiring diagram could have come loose and worked it's way through the wheel. I've also seen owner's manuals left in the air handler that eventually got stuck in the blower. This should be inspected to ensure there is not a fire hazard.
I hope this helps and good luck. :-)
Feb 24, 2010 | Friedrich Heating & Cooling
Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Jun 18, 2009 | Dryers
Carrier 58GS150-CB ignites but fan will not blow (Loud Buzzing)
The loud buzzing soud i found to be the fan blower motor. I removed the fan bracket assembly and sprayed a little WD-40 on the set screws and protruding shaft so that sqirrel cages could be removed. (Also marked position of set screws on shaft) once squirrel cages were removed I removed 4 motor mounting bolts. Cleaned sqirrel cages and housings with industrial strenghth rim cleaner to remove solid dirt and will replace motor and capacitor.
BTW thanks for nothing
Nov 22, 2008 | Goodman GMS90703BXA Heater
92 Accord Buzzing Sound below Glove Box
well that's where your ac blower motor is. you may have something wedged in it smacking the blades on the wheel or the bearings in the blower motor could be going out but that would making more of a hum or a grinding noise.
Aug 20, 2008 | 1992 Honda Accord
Loud buzzing noise
oil the blade with clipper oil, a couple of drops on the teeth
Oct 28, 2007 | Oster 76974-160 Hair Trimmer
Haier HWR12XCB Air conditioner Logo
402 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
