Question about Cuisinart Grind Central DCG-12BC Blades Grinder
Coffee Grinder won't start
We have the same grinder. We filled it to the max line but now it won't start.
SOURCE: CCM-16 Series Cuisinart Supreme Grind Automatic Burr Mill (Coffee Grinder)
My CCM grinder eventually stopped working altogether and I had to throw it away. Amazon comments says this is common. But while my grinder was working, it gave the same symptoms. This problem was caused by beans getting jammed and the outlet from the burr wheel being clogged. If that's the problem, cleaning it out is simple.
Posted on Jan 04, 2008
  • 5 Answers
SOURCE: Stuck Grinder Bowl
This happened to mine this morning. I was so frustrated because the reason I bought this was because of the removeable bowl. My bf got it off but he broke off a piece of plastic (he is pretty sure the piece of plastic was on the bowl part).
I put it back on and it kind still worked- I think I will just need to get a replacement bowl now - but it was hard to get off again.
When I tried to get it off the second time, I moved it into the "unlocked" postion and then manipulated the the blade part while pulling and it came off - but of course mine was broken already.
There appears to be two areas where it locks - on the base and a part on the bowl. I think somehow they get out of synch.
The problem is not with the base I think but with the bowl.
Although, now that it is "sorta" broken - I can't remember what parts were supposed to be loose before and which ones were not. The blade part of the bowl is very loose now. My boyfriend is pretty sure the plastic broke off the bowl part so I am going to get another bowl. I hope that solves my problem!
Posted on May 28, 2008
SOURCE: cuisinart burr coffee grinder
The best solution I have was referred to me by a mate of mine who services commercial coffee machines.
Step 1. Remove the base of the grinder... this is actually the hardest aspect of this task... as there is one tamper-proofing screw... if you can't get the correct star-hex screw driver I recommend drilling the screw out.
Step 2. Once the base is off you will see the main shaft of the grinders motor. The shaft has a star washer set in behind hew nut, the end of the shaft has a slot cut into for a flat bladed screwdriver. Hold the nut with a pair of pliers & you can adjust the shaft positioning (& hence the burr attached to the motor) by about 3mm....
You will need to experiment to find the correct level of fineness as you require.
If you need further information send me an e-mail as I'd be happy to forward more detailed instructions.
Good Luck.
Cheers.......
Dave (dave@kingkiwi.f9.co.uk)
Posted on Nov 04, 2009
  • 547 Answers
SOURCE: My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Posted on Jan 30, 2010
  • 3 Answers
SOURCE: cuisinart coffee grinder keeps clogging
Unplug first. Unscrew the top. You need a long thin screw driver Phillips head is the best. Pock around the exit and entrance where the coffee beans are ground. Remember, the better the coffee and you will get more clumping of the beans. I works great. It is pain. The Chicago Clout man exits.
Posted on Mar 13, 2010
Fill beans
the coffee beans are not entering in the grinder disks and since they rotate without coffee the machine understands that their is no beans. You need to clean the grinder disk and grinding coffee funel to bee sure their nothing blocking the coffee movements. Use a vaccum cleaner and try to clean everything in grinder and grinder exits. Try also the machine by regulating thegriding to more gross coffee and when it will start grinding normal then you can udjust step by step back to grinding position you have at the begeining.
Feb 27, 2012 | DeLonghi ESAM 5500M
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
My coffe comes out too watery. the grinder is set at max (fine grid) is there another setting for the water? or to maximize coffee grinds?
Remove all the beans in the grinder chamber, then remove the screws and slowly lift the chamber about 1 inch high, then turn adjustment knob 3 numbers back and lower chamber making sure the gears on the bottom line up.
Feb 28, 2011 | Saeco Incanto Classic Espresso Machine
I keep getting "Fill Coffee Bin" when the bin is
Sounds like the grinder is blocked. Set the grinder to the coarsest setting (largest number) and try a few more times. If still no luck then vacuum out all the beans, run the grinder again a couple of times and then add a small amount of fresh beans (not from a fridge or freezer as these will be moist and can cause problems) and try making coffee again. If after a few tries it still doesn't work then you will either have to remove the top grinder burr and clean both burrs (not recommended unless you are bit of a handy person) or you could try vacuuming out the beans again and letting the grinder dry out for a while (although unlikely, it could be wet from water spillage). Good luck hope this helps.
Dec 14, 2010 | DeLonghi EAM3400 Espresso Machine
Jura F70 Grinder stopped working
The switch or photo sensor is not sensing any beans present.
So it can't continue
Use torch to inspect bean entry area
Small brush etc
Apr 18, 2010 | Jura Capresso Coffee Makers & Espresso...
It is says fill the beans even if the are full, snd dont make a coffee
Your grinder is probably clogged with fine powder. Set the grinder adjustment to a coarser grist, and see if this pushes out packed coffee from the grinder. Open the lid for preground coffee and clean out the outlet from the grinder.
It is the tamper in the brew unit that feels if there`s enough coffee before brewing. If this gets to far down during tamping, it will send a message to the mainboard that there`s not enough coffee, and the message Fill Beans will appear.
Aug 02, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Coffee watery
Setting your dose at max and grinder at finest is not good. This means that you are asking the machine to grind coffee really fine, and then dose maximun amount which can lead to the grinder getting clogged. If you are looking for stronger coffee, it is best to have several shots that one that has too much coffe and too fine. For stronger espresso, use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee which could clog your grinder and door/channel. At this point, you need to clean the grinder ( inlcuding the door/channel). I suggest you have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 15, 2008 | Saeco Caffe Charisma Espresso Machine
Cuisinart Grind Central  DCG-12BC Blades Grinder Logo
89 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
