Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
RP 2100 dropped thermostat to 65 and locked me out
I just installed a used rp 2100. At first it fired up great. The water temp was 72 and I set the thermostat to 82. It heated for about eight hours reaching about 80 degrees. I checked on it later and the thermostat setting dropped to 65 on its own. I tried to turn it back up but the panel wouldn't respond. I turned of the switch on the side and then turned it back on. It allowed me to reset the thermostat, but when I set it higher than the water temp it sparked and them immediately returned to 65 and locked me out. I did this several times with the same result. I then turned off the breaker to the unit and left it off for a while. When I powered the unit back up it functioned correctly. After a few hours I went to check on it and it was back to 65 and locked out. I repeated the breaker procedure which made it function properly for a while but then returned to 65 again... Any suggestions?
  • jshoro Jul 02, 2009
    I also think it is giving an "A7" code (display isn't great) which I can not find a reference for
  • 22 Answers
You have a bad thermostat board.
Posted on Jul 10, 2009
There is power going to my rp 2100 because i can here a humming noise which i think most be a transformer working,but there are no lights come on and when i turn the on/off button to on nothing happens....
go to the master box and be sure no fuses are in need of reset there..then raise your water temp a few degrees..may also need to see if the burner comes on..inside..if not call your service company whomever they are..I worked for westport pools, we used to install these things.. I was in the construction part, we had a seperate service crew..but I did learn some stuff about these..
Feb 02, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
I have a pool heater RP 2100 you set the temperature it calls for the spark -then there's usually a poof and the flame icon comes on, and the heater heats up. Now set temperature, Calls for heat -the spark...
make three attempts to get heater running. most electronic ignition heaters will lock out after 3-4 times. after it locks out error codes should present themselves.....such as ignition failure, prs, etc.
ensure proper gas and water pressure. check voltage supplied to your raypack's igniter aswell. if heater fires up then instantly shuts off, then it may be the flame sensor
Oct 04, 2013 | Pool & Spa
ROL keep displaying on my raypak rp 2100
check gas pressure if too low it will overheat replace rollout fusible link if it happens again you might need a vent stack
Jun 23, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have an RP 2100 pool heater and the minimum temperature set point is 65 degrees. Every time the pool/spa temp falls below 65 degrees, the heater automatically turns on. How can I either disable this...
Do you have an electrical switch that turns this heater on/off?
Can the heater be unplugged?
Is the heater on a separate circuit breaker that can be shut off for the season?
Nov 27, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
External antenna support for Dlink 2730b.
You should be able to. Most Dlink wireless boxes use a RP-SMA (rp=reverse polarity) connector on the external antenna. So you make or buy a cable to go from the male RP-SMA on the box to whatever is on the antenna (female RP-SMA obviously if you use the same antenna).
If you are going to go to the trouble, I would suggest buying a better antenna also. A directional like the small parabolic dishes work well if getting the signal from once direction.
Jul 15, 2010 | D-Link DI 514 Wireless Router (DI-514)
Raypak 2100 digital display on start up goes through
There may be a buildup of carbon on your pilot or your gas pressure may be low. It is hard to say without more info on the heater, gas line size and meter size. Depending on where you live it could also be something like spider webs in your gas orfaces. These will cause all to fire normally but not be consistant enough to read fire back to the ignition control. A small piece of bent wire into the orfaces will help to clear this up. As it is not a heater related problem it will not show a ready made answer on the display. Hope this helps, let me know.
Oct 24, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
234 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
