Panasonic 25'' 4:3 CRT Vertical collapse.
Hi all, I'm new here so HELLO to y'all! Hope all is good! :-)
I have a Panasonic 25'' PAL CRT 4:3 ProLogic television (TX-25AD1DP). The tube has a vertical collapse.
I know the risks involved with repairing CRT's, high electric store etc.
Would anyone have any advice on how to repair this issue myself.
P.S. tapping/light banging on the case does not have any effect.
Any help would be much appriciated.
Many thanks in advance.
Andrew.
    Genius:
  • 1,550 Answers
Change the vertical IC they are damaged
Posted on Jul 02, 2009
  • laryy56 Sep 19, 2010
    where can you find the vertical ic? what does it look like? do you have to remove the card it's on before soldering?
Sony KV-28FX68B (AE-6B Chassis) starts up ok. Occasional horizontal breakup/flashes but eventually vertical collapse (few minutes to few hours) & blinking standby light (4 times). Checked for dry...
Hi
Please check around vertical outpu IC for bad solder joints and you can try to replace the electolitic capacitors in vertical output line. Check if vertical plug (which comes from deflexion coils) is well attached in place.
Sully
Sep 27, 2013 | Televison & Video
Tv on appears black screen with a bright horizonal line in the middle sometimes with voice
You will have to resolder the vertical IC and in most cases replace any capacitor that is near and next to the vertical IC. There may be three capacitors that will be replaced, And while you are in the process of reworking the board inspect for any and all grounds that may need resoldered. You will have to look very close to find these. And you should search the deflection side of the board for two capacitors that have a 160 volt to 250 volts at 1MF, or 2.2 mf or 4.7Mf. By now these little guys are weak and need replaced. Thanks for asking and show a few hands of support!
Jan 27, 2011 | Panasonic CT-32G23 32" TV
VERTICAL COLLAPSE WHAT IS THE PROBLEM
This can be as simple as poor solder connections at the vertical Ic to a defective IC. The parts cost for this is usually around $25. There are capacitors in the vertical circuit that should also be checked and/or replaced.
Dan
Aug 25, 2010 | RCA TruFlat 27F520T 27" TV
I have a panasonic tv with retrace lines at the topI
If you can locate the vertical IC you are nearby!. You will have to resoder the grounds on the vertical IC and any cap in the immediate area of this vertical IC is weak. I would replace them all as they will pull each other down. There may be four caps and the largest one, possibly a 25 volt 2200MF would be the only good cap. I dont have the specs on this set, but this will surely lead to a good repair!
May 06, 2010 | Panasonic CT-32D31 32" TV
Panasonic CT-27SL15 has scan lines on top 4 inches of screen, what is problem and how to fix?
Nov 2011 - Comment
Have similar problem on a Panasonic Tau model CT-27SL15.
It's a 27" CRT TV manufactured around 2005.
Other posts / solutions on this problem say possibly a capacitor going bad in the vertical circuitry / near the vertical IC / vertical blanking circuitry. Telephone call to a TV repair person mentioned something similar - "possibly a bad capacitor in the vertical circuitry".
Found a service manual online w/schematics and board layouts.
Panasonic Service Manual
http://dl.dropbox.com/u/35219914/PANASONIC%20CT27SL15.pdf
See pg 25 (of 42) - Deflection Schematic Diagram (Main PCB)
Shows: V Output IC - IC401
Finding the actual bad component(s) may not be so easy.
Anyway ... just wanted to add this comment.
Feb 11, 2010 | Panasonic CT-27SL15 27" TV
Picture screen
Hello! You have vertical collapse. There are bad solder connections at the vertical output IC. I have repaired MANY panasonic tv's like this. Very easy to repair if you have any soldering experience. If soldering does not fix the problem you need to replace the vertical IC. Good luck
barneyluc
Oct 06, 2008 | Televison & Video
Panasonic CT27D30B
refrigerant, set is in vertical collapse which requires the replacement of the vertical output IC, probably going to need a tech for this one, questions? e-mail me, BMW Rider
Jan 14, 2008 | Panasonic CT-32SL14 32" TV
Pal to NTSC
If you bought a converter it would convert 25 frames a second to 29.97 or 30 frame 625 to 525 NTSC no adjustments and thats been that way for decades. You can rent a sony or Aiwa deck with legal converter on board and do this easy. So go and get a real converter!
Dec 08, 2007 | Televison & Video
Tv tube problem
It`s total vertical collapse, which means 3 possibilities, vertical IC has failed, vertical IC solder connections are broken, the B+ line (voltage to make IC run) to the vertical IC has failed. None of these problems are big dollar repairs, 1/2 hour repair by any qualified tech, Good Luck & Happy Holidays, BMW Rider
Dec 03, 2007 | Televison & Video
Weird TV
the audio is perfect, but the screen vertically squeezes to about a quarter of an inch and stays horizontally regular. it is due to vertical section of your tv has failed. it is a common problem if you are not a tech person call tech to fix it. solution 1 check vertical section supply. 2 check components in vrtical output stage. 3 check vertical output ic. 4 loose contact in vertical section it is not a major ptoblem. good luck.
Oct 06, 2007 | Panasonic CT25G7 25" TV
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
