Question about Intel D845HV (735858149143) Motherboard
How to connect front side usb port and front side green, red light to the motherboard 845
  • 144 Answers
Http://download.intel.com/support/motherboards/desktop/d845hv/A6513601.pdf
Page 68 and 69
If you found this useful , please rate my solution below
Kind Regards
1234s282
Posted on Jul 03, 2009
Connecting usb
Usually red white green and black unless the motherboard has a cable connect lead already
The USB Pinout:
Pin
Name
Cable color
Description
VCC
Red
+5 VDC
D-
White
Data -
D+
Green
Data +
GND
Black
Ground
http://pinouts.ru/SerialPortsCables/usb_cable_pinout.shtml
http://pinouts.ru/Slots/USB_pinout.shtml
http://pinouts.ru/connector/4_pin_USB_A__USB_B__mini-USB_jack_connector.shtml
hope some of these will help you
Feb 24, 2012 | Foxconn 6100K8MA-RS Motherboard
How do i hook up usb button in intel 845 motherboard
Well, that's a start. You know you have an Intel motherboard in your eMachines, that uses an Intel 845 motherboard chipset.
It is an Intel D845GVSR motherboard.
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Left-click on the blue -
Intel Desktop Board D845GVSR Product Guide (PDF)
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
(I would advise upgrading to Adobe Reader X { 10 }, however, if you don't have it )
After you click on the above link, it may take up to 30 seconds before the first page comes up. (Took 6 seconds just now. Adobe Reader X, and medium speed DSL connection)
At the top of the PDF file, is the PDF file page number box.
It is to the left of the Down Arrow.
Go to Page 11.
T is the Front Panel USB header.
This is where the USB ports on the front of the computer, (Front Panel) connect to.
Go to Page 31.
E is the Front Panel USB header.
The Front Panel USB header is J9F2.
Observe the numbers next to the pins.
Go to Page 33.
This is the pinout for the Front Panel USB header, using those contact pin numbers.
1, 3, 5, 7, and 9 = one USB port
2, 4, 6, 8, and 10 = one USB port
Notice pins 9 and 10 are not used.
You can connect two USB ports to this header.
The pinout of ANY USB connector, female, or male, is set to a Standard.
This is the standard pinout for USB connectors,
In case you cannot download the Intel D845GVSR motherboard manual;
Looking at the motherboard in it's normal position, installed into the computer case, the USB header is on the Bottom edge of the motherboard.
It is to the immediate Right, of the bottom white PCI slot (PCI 3)
It is to the Left of the motherboard mounting hole.
It is Below the Intel 82801DB, Southbridge chip.
Two rows of pins.
5 across the Top row, 4 across the Bottom row.
STARTING on the Left side, (Towards the white PCI slot), and going towards the Right, the pins on Top are numbered,
Pins 2, 4, 6, 8, and 10
STARTING on the Left side, (Towards the white PCI slot), and going towards the Right, the pins on Bottom are numbered,
Pins 1, 3, 5, and 7
Pins 1, 3, 5, and 7 = One USB connection
Pins 2, 4, 6, and 8 = One USB connection
Pin 9, and Pin 10 are Not used. (N/C. No Connection)
A) Pin 1 is for Power
B) Pin 3 is for D-
The Data, or Signal wire. It is the Negative connection
C) Pin 5 is for D+
The other Data, or Signal wire. It is the Positive connection
D) Pin 7 is for Ground
Going to the other USB header;
A) Pin 2 is for Power
B) Pin 4 is for D-
C) Pin 6 is for D+
D) Pin 8 is for Ground
For additional questions please post in a Comment.
Out of curiosity which eMachines is this?
Regards,
joecoolvette
Nov 24, 2011 | E-Machines eMachines Desktop PC
Asus 845 chipset pb4 mother board not starting
it may be the circuit problem,inside the mother board.send it to service center
Jan 16, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Front USB ports
Try here to dload manual which should tell you which is which
http://www.asrock.com/mb/overview.asp?Model=P4VT8%2B
hope that fixes it for you?
Jan 06, 2008 | Asrock P4VT8+ P4 PT800 Prescott Ready...
Usb not working
front USB ports are an extension of a header on the mainboard, it connects via a bunch on individual pins, if any of these pins are wrong the front USB will not work, but usually this would lock up all USB and the ones on the back will not work either, i would suggest the front USB panel was either not connected at all, or it was conected wrong, usual USB header colors of wores is BLACK, GREEN, WHITE, RED, note all mainboards are different, so the black could start from either side of the header, b sure to refer to your motherboards manual for exact pin loactions on the header
Dec 05, 2007 | Gigabyte GA-945GM-S2 (0818313003065)...
Front Side USN dows not work in ASUS M2N MX SE
The front side port may be a "low power" USB port, it may be possible to "power" this if there is the capacity to connect a power cable to the front panel USB adapter, or there may be an aux power socket to plug into on the motherboard.
Nov 04, 2007 | ASUS M2N-MX Motherboard
Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Jun 01, 2007 | Intel Motherboard
Intel D845HV (735858149143) Motherboard Logo
433 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
