Question about Kenmore Elite Oasis 27052 Top Load Washer
Hotpoint Washing Machine smells mouldy as has mould
I have had a Hotpoint Washing Machine for the last 3 years and have done most of my washing on cold cycles. I heard this week that this will cause a build up of mould on and under the seal at the door - which has now happened. The mould has started to smell.
I was sold some descaling powder to help with this problem and told to run the machine on a hot wash with nothing in it with the powder. I have done this twice now but the smell is still there. Does anyone have any other suggestions about how to get rid of the mould - could we buy another seal or will we need to get a new washing machine?
    President:
  • Kenmore Master
  • 662 Answers
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Posted on Jun 03, 2010
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
Hotpoint WT 960G Smell from the machine when in use.
Usually the smell is caused by bacteria from the soiled water when washing is done on a cool wash. I have told customers before that to clear the smell you need to do several hot washes maybe using your white so as not to fade or run colours and in time the bacteria will clear and smell will also.
Feb 03, 2016 | Hotpoint Ultima WT960P Washer Front...
Error E30 flashing on washing machine
What brand. Ih it is a hotpoint. I found this on the net from a washer help site in the uk
Error 30 (on Hotpoint) just means the motor isn't working. Several things, including the power module, can cause this. The most common cause though is worn carbon brushes. There is also a 7.5 amp fuse on or near the power module, which can blow. This fuse is on the motor circuit to protect the circuitry of the power module. If it blows, then the motor won't work and you will get error 30.
If it has blown, it's likely to be caused by the motor. I had one last week where the armature in the motor had shorted to earth which blew the 7.5 Amp fuse.
To check the brushes, with the machine unplugged! Have a look at my Hotpoint and Creda carbon brushes diagnostics You can also Buy Hotpoint & Creda carbon brushes
Jul 18, 2014 | Washing Machines
Where is filter on my hotpoint aquarius wmf540 washing machine, im getting white fluff over all my clothes everytime i put a wash on, im guessing the filter needs cleaning and just wondered where it is
http://laundry.manualsonline.com/manuals/mfg/hotpoint/wma58_wma56_wma54_wma52_wma50_wmm59_wmm53.html?idRes=599752
see last page.
also, you should try run a cycle without any clothes (add a bit of bleach) in it in cold water for once to rinse out the dirt.
Oct 02, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hi i had my washing machine repaired last week as the bearings had gone and it needed a new drum (luckily it is under warranty). Now 6 days later there is water coming from the bottom and the washing...
to find the leak take your lid off + the access panel on the back now turn it on if u still cant find the leak tip it backwards and have another look but it could be a fault theyve done by not sealing the 2 halves of the outer drum if thats the case they should come out to it straight away or get in touch with the trading standards because it has only just been done and it must be something theyve done if it wasnt leaking before
Dec 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Leaks after wash programme ends
Check your inlet hose or hoses if it is hot and cold fill.
Turn off supply to washer and see if it still leaks, if it does then you have water coming from inside m/c somewhere
Nov 23, 2008 | Hotpoint Aquarius WD63 Front Load...
With my hotpoint washing machine the clothes are soaking wet at the end of the cycle, don't know if its not spinning properly or what?
hotpoint machines are renowned for needing carbon brushes to be replaced in the motor they usually last between 12 months to 2 years depending on the amount of use the machine has.i would check these first as they are a common cause of hotpoints not spinning, if they are ok then check the pump and sump hoses for blockages (not emptying water out)
Jul 15, 2008 | Washing Machines
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Jan 06, 2007 | Hotpoint Aquarius WD63 Front Load...
Kenmore Elite Oasis 27052 Top Load Washer Logo
305 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
