SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
SOURCE: How do I remove the PTO clutch from a John Deere
Locate and disconnect the power supply cord from the clutch. Remove the bolt, washer and retainer from the center of the clutch, It should now slide off the end of the crankshaft provided you have previously removed anything such as body parts or braces that would be in the way. In some instances penetrating oil must be used to help free it up. When you reassemble it, it is a good idea to use a little bit of anti-seize on the engine shaft in case you have to remove it in the future.
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
