Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Starts OK but after about 15 or 20 minutes starts losing power and after moving throttle up and down for five minutes or so to keep going dies After cooling for twenty or thirty minutes will start and go through the same routine. Problem seems to be too much gas or not enough.
    Problem Solver:
  • 5 Answers
When your ignition coil get to engine temp. it will begin to lose its power, therefore your engine will eventually shut down, when it cools it will start up again,
Good luck
Posted on Jul 02, 2009
97 Nissan Sentra runs fine for about 2 miles then starts losing power and dies wont start back up for about an hour
Check Engine Light/Loss of Power Due to Throttle Body Unit ...
repairpal.com > Problems > Nissan > Sentra
The electronic throttle actuator (throttle body) can fail causing a loss of power ... start it studders like it is running on 2 cyl. then switches to 3 cyl. then to 4. but ... Throttle body replaced on my 2006 Nissan Sentra 1.8 engine. ... I Was going up a hill and I tried to speed up, all of a sudden my car bogs down and completely dies.
Nov 17, 2015 | Nissan Cars & Trucks
Motor starts fine runs for five minutes then dies starts back up back up fine but no throttle response after thatfine.
if there is electronic throttle then probably needs replacement, get second hand one , or otherwise can try to take it out and clean it, if there is an access to electronic part of it try it open carefully and clean contacts with some alcohol, sometimes it helps
Apr 16, 2014 | Cars & Trucks
2013 Sienna starts and dies. No fault codes. If I give it more then 50% throttle and play with it It will stay running. Anything less and it dies. Starts up normal but dies almost immediately. No Antitheft...
no fault code where? on the Pro OBD2 scan tool screen>?
should be in warranty, why not let them fix it?
tow it there.?
bravo that, first post ever with fast right foot test, you are on the ball.
ok, that means this.
1: it's not losing 12vdc power to run the EFI. all lamps are not dim.
2: the fast foot test, implies to me, spark is ok, (unless one cylinder shut down, a bad COP?. but the scanner will see that for sure and did not. Gross misfire, is never unreported by the scan tool. (PCM)
gross enough to stall the engine.
so fueling issues.
id check for flooding or starving for fuel. and bad fuel.
Ok so my guess, is its losing fuel pressure or you got bad fuel.
Feb 16, 2014 | Toyota Sienna Cars & Trucks
1998 chevy k1500 runs rough no power untill it warms up
This could be due to any or all of the three sensors going bad: oxygen sensor, throttle position sensor or the MAF sensor. Connect the diagnostic tool if the check engine light is ON to find out the codes, as this would narrow down your problem.
May 21, 2013 | Cars & Trucks
2.8 hilux keeps losing power
check for fuel problems like air/fuel leaking at pump at the throttle shaft.
Mar 31, 2013 | Cars & Trucks
Husqu51 starts once but dies then just turns over
take off the muffler and try it if ok then open it up and clean the carbon from the screen
Apr 02, 2012 | Garden
Hi i have a shoprider of witch is still running but one min it will go full speed then it can die as if it not getting the full power and slow right down and then for no resson will take off again or if it...
hi Dave, it could be a number of things,
1. Firstly the throttle pot ,When the scooter starts to slow down , gently push the wigwag (throttle lever ) in the upwards or downwards direction to see whether it corrects the slowing down, if it does keep it there, if it seems to fix the problem you need a new throttle pot.
2. What 's happening to the battery power meter ? is it fading or moving ? Weak batteries or a dodgy charger
3. Motor brushes not inserted fully or worn
4. Controller issue (Rare )
Regards
Rob
www,gewizrepairs.co.uk
Feb 03, 2018 | Shoprider Sprinter XL4
Mayfair freerider mobility scooter - keeps losing power, especially on slow speed
ok, sounds like the speed pot,
Can you move the throttle lever up and down, try going along at a constant speed (losing power ?) then move the lever up & down ?
does it improve response ? if so replace the speed pot.
Regards
GeWiz.
Oct 18, 2009 | Health & Beauty
Fuel system
Check the fuel system, chenge fuel filter. clean the fuel tank.
Oct 16, 2008 | 1994 Toyota T100
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
444 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
