Try a hard reset. The 10" Irulu has a reset on the right bottom edge. You'll need to stick a sharp pointy pen that fits in the in the small hole, push. Press the ON button and see if it starts. Resetting will change the time and date to the default setting of your unit.
here are some links for info on brick tablet fixes. but some works most don t. and i cant tell u to return it asap for a new one or refund.so here u go. good luck chad man http://androidtabletnotworking.com/
Have you tried the hard reset? Try these instructions for a hard reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
