Question about Sharp AR-M205 Copier
Have an error message L6 on a sharp ar-m205 how do I correct
Machine won't work
  • ashwaj May 11, 2010
    try to change LSU unit
    Problem Solver:
  • 5 Answers
Try to change the LSU unit
Posted on Jul 04, 2009
My Sharp AR-M205 Copier has developed a problem. The code L6 is flashing up on the Display panel. Someone suggested I might be able to fix it by 'resetting' the machine. Can anyone advise how precisely to...
L6 is polygon motor lock (in the laser unit). To try and reset on the keypad press P * C * (pound star clear star) and enter sim 14 and press copy button. the machine should restart if down right. If the code comes back the LSU unit will need to be replaced. Should be done by a trained tech.
Aug 25, 2010 | Sharp AR-M205 Copier
When it displays error message l6
may be it is L6.if this then change laser unit
Apr 16, 2010 | Sharp AR-M205 Copier
Sharp AR-M205 - Error Code L6
L6 10 Content Polygon motor lock detected Detail It was judged that there is no output of polygon motor lock signal of LSU. The lock signal was checked at about 10-second intervals after the polygon motor started rotating. As result, it was judged that the polygon motor failed to operate normally. Cause Disconnected connecter to LSU or detached harness inside LSU or broken wire. Polygon motor defective Check and remedy Check polygon motor operation with SIM61-1. Check harness and connector for connection. Replace LSU if needed
Dec 14, 2009 | Sharp AR-M205 Copier
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
I have a sharp AR-m205 with a flasing l6-10 erro message. Can the machine be reset?
Hello sir; the code you display,can not be reset, the problem of it, is laser motor bad you need to replace one.
Jun 11, 2009 | Sharp AR-M205 Copier
I have an AR-M160 and have an L error. How can I
this L6 ERROR IS USUALLY TO DO WITH THE POLYGON MOTOR IS IT L6-10
Error Code
L6 means : Rotary cassette position sense failure
The Cassette position sensor is defective, or there is a failure in the RC motor .
Call Sharp support using the phone number listed on the owner manual.
Nov 16, 2008 | Sharp AR-M205 Copier
Sharp display error
hi!
your ploblem is en the poligon motor,,,replace it with a new one or you can remove from the machine and look if needs a little bit of oil.
May 24, 2008 | Sharp AR-M205 Copier
Sharp AR-M205 Copier Logo
258 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
