Question about True GDM-12 Refrigerator Commercial
Missing plexi glass sign for my unit
I just got a coke GDM-26 merchandiser and am in need of the plexi-glass sign for the top. Please guide me where to find this.
THANK YOU!!!!
    Problem Solver:
  • 7 Answers
These are referred to as 'signfaces'. I have one just laying around that says 'cold drinks'. I would suggest measuring it out and buying a piece of plexiglass from home depot, then going to kinkos and having them print out a similar size sticker to attach to it.
Posted on Aug 13, 2009
Why does temperature fluctuate between 30 and 65 degrees all day long?
Check and clean the condenser, set thermostat to 3 or 4. If still problem persists, change thermostat.
Dec 08, 2015 | True Refrigeration Black True GDM-33SSL-54...
Ajust temp on true gdm 26 f
Hello Tam;
My name is Peter. I am a retired field service refrigeration technician.
The following manual link has the instructions for adjusting your unit temperature.
http://www.truemfg.com/assets/InstallationManuals.../GDM/gdm_english.pdf
Jan 24, 2015 | True Refrigerators
I have a coca cola cooler and it keeps running is that normal
same question as is on your post I have coke machine GDM-23 or AE44OA it keeps running and gets a frost build up on tube at top
Jul 11, 2012 | True GDM-12 Refrigerator Commercial
How to put plexi-glass in convertable top
That requires allot of skill and special equipment.
Jun 15, 2012 | 2001 Saab 9-3
How do you remove the screen frame to remove broken glass? Can the glass be replaced with a piece of plexi glass?
hello am rico, no you cant, unscrew all the screws from the back and bottom front. should be able to open it. if you need more help let me know. 602-810-7149
Jan 07, 2011 | Sony KP-51HW40 51" Rear Projection...
TRUE GDM 26 merchandiser has sealed lines to the freeon and cant access. The fan blows warm air and all the lights work. It just doesnt cool.The compressor was cleaned only 2Xs in 3 years.
What do you mean the compressor was cleaned. It sounds to me you need to clean out the condenser coil. free it from all dust and debris. + Does the compressor work and what gas is in the system, does the condenser fan work. I'm assuming that when you say the fan works, it is the evaporator fan inside the cabinet working. You will have access the condenser fan either from the front or rear of the unit. The condenser unit is normally extracted from the rear. it should slide out but take care not to kink any of the pipework.
Apr 17, 2010 | True GDM-26 Refrigerator
We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
GDM-26 humidity very high
assuming fridge is at correct temp, i suspect fault is with your humidity detector. the humidity inside a fridge is a lot less than the outside air
Oct 09, 2008 | True GDM-26 Refrigerator
True GDM-12 Refrigerator Commercial Logo
125 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
