I was vacuuming and noticed that the bag needed changing. the red light with the ! inside the triangle also came on. When the bag was changed, the vacuum would not restart. The red light came on. Tried the reset button but nothing happened. Tried unplugging and re-plugging in and nothing happened. Replaced all the filters and still it wouldh't start. So I brought it downstairs and tried one more time to get it to start. it worked! Is there something wrong with the vacuum cleaner? Was it overheated because of the bag needing replacing? I can't find the manual but the vacuum says "Miele Aluminum" and it is a cannister. I have guessed about the product number below.
I need to see a vacuum hose diagram for a '86 chey 305 4bb carb .... I have dry-rot hoses and some...
(More)
I need to see a vacuum hose diagram for a '86 chey 305 4bb carb .... I have dry-rot hoses and some of the hoses is not going to nothing and I need to know where they suppose to go. I bought a fixer-upper and it's fixing me.
replaced the bearings both 240vac motors and have reassembled the lot but have misplaced my wiring...
(More)
replaced the bearings both 240vac motors and have reassembled the lot but have misplaced my wiring sketch i drew to rewire the unit it includes a 24v relay with 8 screw terminals on the mounting block the relay unplugs from the block
The Dyson motor turns on, but the brush is not turning. What do I do? If it is a belt, we need to...
(More)
The Dyson motor turns on, but the brush is not turning. What do I do? If it is a belt, we need to know where it is located and how to get into it.
My wife has a Miele S548 Vacuum. Now when she pulls out the retractable power chord past a certain...
(More)
My wife has a Miele S548 Vacuum. Now when she pulls out the retractable power chord past a certain point, the vacuum shuts off and the built-in LED display says "700". Can you halp? Alan Metzger Glendale, Arizona USA
I have an S548 Aluminum canister vac that's about 6 years old. Tonight while I was vacuuming,...
(More)
I have an S548 Aluminum canister vac that's about 6 years old. Tonight while I was vacuuming, the LED on top of the powerhead that is normally green turned red and the brush stopped spinning.
I took the brush cover off the bottom, took off the top cover, took off the inner cover. The wiring and connections all seemed to be intact. I took the back cover off the neck of the powerhead (where it connects to the wand) and the two yellow wires in there looked good too.
I suspect the powerhead may need a new motor. Can someone let me know what the red light might mean.
Thank you in advance.
