Question about Brother Office Equipment & Supplies
"Change drum soon mean" in my 7820n?
What does "change drum soon" message mean in my 7820n? (Is the drum the same as the cartridge?)
  • 11,896 Answers
Drum and cartridge are two different things. The cartridge is attached to the drum. They do need to either be cleaned with rubbing alcohol and cotton swab. You can try to clean out the connections. But many o require replacement.
Posted on Jul 02, 2009
It say drum end soon and i dont know what this means as i put a new ink cartridge in it and it still keeps coming up the same.
Your unit obviously has a separate drum and toner.
Changing the toner, doesn't change the drum.
You will need to change the drum soon.
Jun 24, 2011 | Brother Office Equipment & Supplies
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
We've tried 2 new toners in the Brother 7820n and still get the same error...Change Drum Soon. We've turned it off, slid the blue arrow to clean the drum wires, etc....it still won't work...please advise....
Open front cover where drum/toner goes in
Press "Options" key on control panel
LCD will display "Replace Drum 1. Yes 2. No"
Press 1 to reset drum
Close front cover
Nov 09, 2010 | Brother MFC-7820N All-In-One Laser Printer
Is the "change drum soon" message instructing to
This indicator is for the drum unit, not the toner cartridge. The drum unit is the assermbly that the toner cartridge is inserted into when being replaced. The drum unit is replaced about every 18,000 pages so after about 5 to 10 toners have been replaced.
Here is a picture of the drum unit.
Oct 28, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Sep 07, 2010 | Brother MFC-7820N Printer
Change drum soon
There is an easy reset procedure for this.
1) Open the front cover. 2) Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO". 3) Press 1 to reset the drum count. 4) Close the front cover. Good Luck and Thank You for using Fixya.
Jun 03, 2010 | Brother MFC-7820N Laser Printer
How do you reset the toner low LCD message when you change toner cartridge?
I believe you mean, DRUM Reset.
Jan 12, 2010 | Brother MFC-7820N Printer
Brother 7820N, printing image repeats?
have you tried changing the drum unit for a brother oem unoit and oem toner? generic toner and drum will always mess the machine up!!!!!!! good luck brother sr tech
Dec 22, 2008 | Brother MFC-7820N Printer
"Change Drum Soon" Message; not change when we changed the drum.
Description:
Aug 07, 2008 | Brother MFC-7820N Laser Printer
Replace Drum Soon Message
Read your manual. There is a counter that goes off, that can be reset when you change the drum.
With power on and front cover open press set, then select reset drum
Mar 25, 2008 | Brother MFC-7820N Laser Printer
399 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
