Question about LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac
Leapster have sound but no picture. What do i do?
I gave my son a leapster explorer about a month now and it's volume just stopped working and it wont hear anything.
there are three basic reasons why the leapster explorer won't bring out sound.
1. Defective speaker
The speaker of your leapster explorer maybe defective, this can make it not bring out any sound. Disassemble the leapster explorer, check the speaker part, test the speaker with a AA battery. If you hear any sound using the battery, then it means there is nothing wrong with the speaker.
2. Loose wire connection
Disassemble the leapster explorer, check the wires connecting the speaker to the board. Check for any wire cut, or loose connection which can cause the speaker not to bring out sound. . 3. Sound IC/Card/Board
If non of the above is the cause of the problem, then it means the leapster explorer is having a defective sound ic/board/card. There is an IC on the board of the leapster explorer which is responsible for sound. If this ic has a shot, there won't be any sound. If this be the cause, I think it's high time to took the leapster explorer to a repairman because this requires skill.
I hope the above is clear. If not, please let me know for further assistance.
Regards.
Aug 10, 2011 | LeapFrog Leapster Explorer Learning Game...
When the main screen comes on and says touch your name with the pen it does not resond what do i do?
It sounds like the TouchScreen needs to be calibrated.
1. Hold down the Hint button while turning the Leapster on.
2. When the Leapster menu screen appears, press the A button.
3. Touch each of the crosshairs that appear with the stylus.
4. Restart the Leapster.
Hope this helps!
Feb 27, 2011 | Leapster 2
Leapster gaming learning system got no sound.i've tried inserting the headphone and rotating it twice 360.degree but still no sound.
Speakers sound blown. Contact Leapster company they will tell you to sent it to them and they will send you a new one at no cost.
Jul 11, 2010 | Leapster Learning System
The sound on my sons leapster 2 has stopped
1.You can get a full refund 2.you can contact customer service 3.buy another one whith your refund:)
Oct 15, 2009 | LeapFrog Leapster 2 Learning System
Leapster 2 showing white screen
I'm really not sure at this point -- there aren't to many things you can do with a leapster to fix the display....how old is it? Wondering if Leapster will do anything for you if it's too old to exchange at a store. Typically screens turn white if they need to be refreshed OR if they have overheated or been left in a car or a hot place -- because the lcd gets messed up in extreme heat. Wished I could help you more then that...but calling leapster sounds like your only option right now..unless exchanging at the store is possible.
Jun 26, 2009 | LeapFrog Leapster Electronic Book:...
Sound is cracking
If you cannot return it at the store, then call up Leapster and you can send it to them and they'll send you a new or refurbished one. I was told this a few years ago anyway. I reached someone out of the US. It wasn't easy communicating with the gal, so I was leary on following their steps, but with a name like Leapster, they do back their products.
May 30, 2009 | LeapFrog Leapster 2 Learning System
Brand new leapster no picture has sound but display is blank
Calling LeapFrog right now for the same problem.
First, they suggested cleaning the battery contacts.
Now they're stepping us through recalibrating the screen.
Now they're asking where and when we purchased it.
Answer - take it back to the store.
Leapfrog gave us the only solution to return and get a new one since we did have the receipt.
Dec 07, 2008 | LeapFrog Leapster Electronic Book:...
Dark screen on leapster
There are two buttons on the Botttom of the leapster. One is brightness one is dark. You probably turned it to dim.
Nov 11, 2008 | Leapster Learning System
Leapster L-Max with No Sound
We had the same problem and I found the speaker was broken. Radio Shack part # 273-0092 is almost a direct replacement. Under $4 and works like new now.
Feb 16, 2008 | LeapFrog Leapster Electronic Book:...
LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac Logo
Top LeapFrog Computers & Internet Experts
Alun Cox
Michael Cummings
Level 1 Expert
k24674
Are you a LeapFrog Computer and Internet Expert? Answer questions, earn points and help others
