Question about Garden
My s2348 battery lite is staying on,what is the most likely cause,stator or cdi looking box on side of engine?where can i get a good elec diagram for this tractor?
  • 513 Answers
What brand & model# i can help if i have further info thanks wade
Posted on Jul 04, 2009
Have a gy6 50cc nospark, how to check coil ignition switch, ignition kill switch, cdi , and stator alsojust overhauled engi e it boggs out ? PLEASE HELP !!!!
Hi, Sherman I would really love to help you but due to the magnitude of yesterday's solar flare the batteries in my crystal ball are dead and my mental telepathy headset circuitry was melted. I need the year, make, and model of your motorcycle please click on the word "COMMENT" below and provide this information in the box that will open and then click on the green comment box in the bottom right-hand corner after it posts I will receive an "ALERT" icon that will allow me to respond to your information.
Good luck and have a wonderful day.
Apr 17, 2017 | Motorcycles
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
Cdi
Do not use a universal CDI unless you have the exact wiring cross-over diagram, or have tech help from the manufacturer. You can short out the CDI and other ignition components like the stator.
Apr 02, 2014 | 1985 Honda XR 250 R
No Spark, No Power coming from CDI to coil
Check the wiring on the connector plugs make sure all the wires are the same color on both sides, red to red blue to blue and so on. I had the same problem After replacing a stator and just plugging it in,after two weeks a new cdi and coil i noticed there were two wires transposed.
Aug 22, 2012 | Pit Bike 125cc 4 Stroke Dirt Bike
I have no spark on a sunl 250 4 wheeler i have replaced coil,voltage regulator,and cdi box?
if you have replaced all that it sounds like it is the stator. its an alternator for small engines. get one on ebay cause factory are always expensive. its located behind the pull start. take that off then the side case cover.
Jul 09, 2011 | Zongshen 985 C3 V4 Motorcycles
When idleing the lights go good but when you rev bike lights dim
Follow the leads that exit the crankcase from below carby area and thoroughly check all these connections to CDI unit and Rectifier and Ignition Coil. The wires also then follow thru' engine kill switch and lighting switch, others go to tail and brakelight switch. Are the wires being pinched at head stem or within handlebar switches. If all wiring/swithes and connections are in good order, you have some issues with your stator coils or pick-up coil inside left engine cover and behind the rotor, or the CDI unit. With some luck, the Rectifier or Ignition Coil may be guilty as these are relatively cheap to replace compared to stator coils and CDI. Get an auto. elec. multi meter check done. The Service Manual (info can be asked from Suzi dealer) has the Ohms resistance parameters to test against. Goodluck, and Cheers.
May 12, 2010 | 2001 Suzuki DR-Z 400 SE
What causes cdi box to fail? the big red ran fine,but when trying to resart it the next day it will not fire. Also how do I know if it is truely the cdi box?
many things can cause a cdi box to fail they are hard to diagnose. but as far as testing goes u can use an multimeter to test ur resistence in the stator and coil if they test good its the cdi. or even a bad ground can cause it to loose fire.
Apr 13, 2010 | Honda XR 250 R Motorcycles
I have a chance to pik up a 88 yz 125 for a hell of a price and the guy says it wont start. No spark. electrical problem. says its the stator. I dont know that. So im asking, what exactly I can do to find...
hello, usually you have 3 things for firing problems, stator and stator pickup coil, or ign coil, or cdi, i have a 2000 warrior 350, i just went through all that, you can buy after market cdi from procom engineering inc. i purchased one for my warrior 76.00 , it advances timing, hotter spark etc.most of the time it is the stator, pick up coil, both are hooked up together in the stator case, left side of motor,warrior cdi usually goes bad, havent heard of cdi on 88 model, may need to check with dealer.
Feb 06, 2010 | Yamaha YZ 125 Motorcycles
1998 yahama snowmobile
if your coil and CDI are good that leaves the stator being bad. I went through this on my sons 350 Warrior this summer.
Jan 19, 2008 | Lite On Spark Plug Lite Green LED
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
