Question about Microsoft Xbox 360 Console
Discs dont read
None of my disc's work. None of my dvd's work it hums for about 5 seconds and tells me to open the tray
  • 767 Answers
If you hear it spin up to the hi speed mode
it is likely your drive is good ie both spindle motor
and worm gear motor .and all you need is a laser :>
the laser is the easy fix ,and cheap about 20.00-30.00
I have never seen a dirty lens just a ring of accumulated dust
in side the drive ,probley because of the hi rpm of the drive
prevents dust from settling on the len.
Posted on Jul 02, 2009
    Genius:
  • 1,550 Answers
Clean the laser lens
DMR ex83 disc tray not opening
With the unit turned off, press and hold the [STOP] and [CHANNEL UP] buttons on the main unit at the same time for about 5 seconds. (Ejection may take extra time depending on discs.)
DO THIS ON THE MAIN UNIT (NOT on the remote)
It worked well for me. Roget
Jan 27, 2014 | Panasonic DMR-E55 DVD Recorder
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
Reads the games but only says close tray and open tray
It sounds like you will need a drvie replacement or motor. Sometimes the magnetic disc on the motor comes loose and it sticks to the top of the dvd drive cover and causes it to not function. We can fix this for you if your interested email us.
xbox360fixer@verizon.net
Jan 11, 2009 | Microsoft Xbox 360 Console
Hey There! philips dvdr3370h After 2 years of no problems. disc stuck in drawer - fixed that Now , none of my discs will play. "error - incorrect region code" PLEASE Help! Thanks! Ben.
Try and see if this will work...
1-Power on the player.
2-Ensure disc tray is empty.
3-Wait for (no disc)to be displayed.
4-Enter 0086000 with the remote control ,then press ok.
5-Then enter with the remote control 00009 then ok
this should verify you have region 0
if it does all is ok.
6-Then you need to push system menu button.
7-The first page you come to will be general
you need to change the video output to ntsc,dont worry it will revert back to pal when you exit system menu..and only has to done once to set the hack.
THIS HAS TO BE DONE TO ALLOW HACK TO READ ALL TYPES OF DISCS E.G NTSC AMERICAN.
I hope this helps.
Plz let me know^^ Goodluck!
Dec 29, 2008 | Philips DVDR3370H DVD Recorder/HDD...
Xbox wont read discs
All CD Players and DVD players work basically the same. way.
When you close the tray a tiny micro-switch makes contact telling the player it is ready to read a disc.
Your switch has either failed or is out of alignment.
The unit has to be taken apart. The switch needs to be adjusted or replaced. The switch is a 69¢ part.
Dec 05, 2008 | Microsoft Xbox 360 Console
Tray will not stay closed
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Nov 21, 2017 | GoVideo D645 DVD Player
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Player won't function
The Lazer is dirty open it take a ear bud then apply alcohol to bud wipe Lazer gently normally you can use nail polish remover to clean
Mar 03, 2017 | Sony DVP-NC655P Multi-disc DVD Player
Microsoft Xbox 360 Console Logo
97 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
