Home | Heaters | Heater won't shut off.
Heaters
Problem for Heaters
Generic problem for all Heaters
By quiqnezz on Nov 09, 2007
So a few weeks back I had turned on our electric furnace for the first time this year by using the thermostat. And when it first started it up it was making a pretty loud rattling/shaking sound. So I went and turned it off by using a the double on/off switch located on the outside of the furnace. I flipped it on and off a couple of times and then the noise went away.
The problem now is that the furnace won't turn off from the thermostat. I have tried setting it to the off position and also turning the temperature setting to a lower degree and it still won't shut the furnace off. I don't think the thermostat is bad as I can hear the distinct "click" of it as I turn it to the off setting and then back to the heat setting. The only way to turn the furnace on or off now is by flipping the switch outside of it.
Do I need to somehow sync up the furnace back to the thermostat somehow? Did I somehow disable the thermostat by turning off the furnace with it's off switch?
Best Solution
posted on Nov 15, 2007
Helpful)
Buffalo12980
Rank: Wiz
Rating: 84%, 1044 votes
you say you hear a click. this indicates the relay is opening and closing, BUT the contacts may have welded itself shut. try replacing the relay - contactor.
Was this helpful?
Yes
No
Solution #2
posted on Oct 04, 2009
Not Rated)
melvinbracey
Rank: Wiz
Rating: 75%, 17 votes
The thermostat normally shut off the furnance, after a few minutes, however I had to replace a couple of thermostat in an apartment complex less than a year old the thermostat was in deed bad
Melvin
St Louis
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
how can you buy things for less than what they ask for?
Answer
What is the safest & most cost effective patio heater
Answer
Our timer on the heating keeps cutting out for no reason. It is like the electricity supply is cut.... (More)
Answer
I need to convert a ProCom Natural Gas heater (model MN200TBA) to Propane Gas. I have not found a... (More)
Answer
Hi, I have a Clarke XR75 paraffin space heater which doesn't start consistently. Once it's going... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heaters:
Top Heater Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
