Question about Dryers
Dryer has water in exhaust pipe and not drying clothes
  • 5,911 Answers
If you have water in the exhaust vent you have a clog somewhere in the line that needs to be cleared. When a dryer exhausts, moisture is included in the air that exits the dryer. This moisture will condensate and collect in the exhaust vent if it has no where to go. If too much moisture builds up this can back up into your dryer's heating circuits. In addition, a clogged dryer actually overheats and dries less efficiently. If the heating circuits continually overheat this can result in component failures and is a potential fire hazard. Inspect your dryer exhaust vent ducting thoroughly from where it leaves the back of the dryer, to where it exits your home. Make sure there are no bends, sags, kinks or clogs in the line. In addition, it is recommended that you use the semi-rigid metal type vent ducting. It resists kinking, is heat resistant and prevents rodent intrusion. If you have questions let me know. I hope this helps you.
PS If your heating circuits are no longer working, you may have a problem with the heating circuits now. The thermal cut-out (TCO) commonly fails. If this is the case, please let me know and I can advise you further.
Posted on Jul 02, 2009
  • michael conroy
    michael conroy May 27, 2015
    Jeff, thanks very much for the info. opened the door of the dryer and steam came out. shut the dryer down. took the piping apart. no lint in the back outlet of the dryer. ran a dryer brush thru the piping and it was clean. there was a little saturated lint in the exit piping that leaves the house. ran the brush thru to the outside. attempted a dryer cycle and the pipe is hot all the way thru and the air is blowing out the vent outside. hope that's it.
Why does my condensed tumble dryer leak water when drying?
Moister in the dryer:
This means that the moist air is not escaping correctly and that is why it is taking so long to dry your clothes - if they dry at all.
a good start at cleaning out lint blocked areas, I suggest go to the back of the dryer and take off the vent pipe or hose and check things out with a flashlight. Clean out all the lint and dust you can, even use a vacuum cleaner on it. Make sure the vent pipe is completely clear of any obstructions.Non-rigid ventshas much worse air flow than smooth piping, so you might want to upgrade tosmooth piping.
Once you have all the lint and dust cleaned out of the dryer, go to where the dryer vents outside. Again, clean the area thoroughly. There is usually a trap door that opens when the dryer air is on and closes when it is not operating. It should be completely clear of lint and opening smoothly.
Also, look into the exhaust area on the dryer carefully to see if there is a hole or gap in the dryer's internal air ducting. Without the vent pipe connected and with no clothes in the dryer, start it and let if run for a few seconds and make sure there is strong air flow from the exhaust port. You should feel it strongly on your hand.
Re-connect the vent pipe and start the dryer again. Feel all around the bottom to see if any air is blowing out from under the bottom. This would indicate there is a break or gap in the dryer's internal ducting. If you do feel air, you will need to call a service technician to see if it can be repaired. If your dryer is very old, there could be a rust hole in the duct.
In conclusion Cause ·Poor venting is a common reason why water might leak into a clothes dryer. Since the dryer works to expel moisture, it is important that the dryer's vents are properly installed so that the humidity can escape.
Effect ·If the humidity in the dryer is trapped, it will eventually turn to water. This will lead to poor drying results or longer drying times, depending on the amount of leakage.
Prevention/Solution ·Faulty dryer venting can be prevented by making sure that the humidity is directed outdoors. Also, vents should be cleaned of lint and other debris before each load so that water can readily escape. Taking these precautions can ensure that the moisture will meet dry, open air.
Read more :http://www.ehow.com/facts_7167266_would-water-dryer_.html
Why Would Find Water in My Dryer eHow
Apr 26, 2016 | Dryers
What is causing water leakage at the end of dryer program when it goes into cool?
Mar 29, 2016 | Dryers
Why is there moisture in the exhaust piping?
The moisture from the clothes is heated up from the drying process and is exhausted through the vent pipe. When the warm air with that moisture cools in the vent pipe it condenses and forms water droplets again much like the water that forms on the outside of a glass with ice water in it.
May 27, 2015 | Dryers
Hirundo washer/dryer fills with water during the dry cycle so clothes come out hot and soaked what could be the cause?
Jun 09, 2014 | Equator EZ 3612 CEE Front Load...
Water under dryer after use. cleaned exhaust lint in it was wet. should i insulate exhaust tubing. fsminatrea@yahoo.com
Hi
Dryer would be either leaking from vent or due to condensation. The vent may either be blocked. The water is coming from the clothes you have dried in the dryer and it has no where to go.
You need to dismantle the vent and clean it, replace it with new vent. The dryer may now be consuming more time to dry the same load of clothes. By correcting the venting problem you will solve the water problem and shorten your wash day and save on electricity as well.
Another issue is condensation which usually appears on the dryer vent pipe colder climates. As the warm air from the dryer is vented to the outside, it must be protected from the cold temperatures outside. If your dryer vent pipe is not properly insulated, the air that is being vented out will turn into water when it comes into contact with the cold pipe outside. This results in condensation and dripping water. To resolve this, you must insulate your dryer vent pipe along its entire length. This will ensure that the hot air from the dryer does not undergo temperature fluctuations, and no water will leak into the vent pipe. Hope this helps... Please post back if you need more information.
Danile
Dec 27, 2010 | Maytag Dryers
Not getting clothes completely dry. Bad smell
The problem is the water in the vent pipe.You will have to empty the water out of the vent pipe. If the vent is running under the house, crawl under, starting at the closest dip to the dryer and work it out to the exterior. Then use some wire or ties to secure it to the floor joists to keep the dips from reoccurring. If there is water in the pipe, then the dryer can't blow the warm, moist air out of the tumbler. It is the equivalent of trying to dry clothes in a sauna. There is nothing wrong with the dryer, it is working correctly. The problem is the vent.
Mar 28, 2010 | Kenmore HE5
DLG5988S gas dryer takes long time to dry cloths in either mositure sensor mode or timerd mode. I have throughly cleaned the dryer exhaust and internal part of dryer where all electronics and controls are...
How long is the exhaust venting system from the dryer to the outside, where it vents? The dryer is not equipped to push air through any pipe that is too much past 8-10'. Each 90 degree bend in the pipe adds 3-5', so a few feet plus a few 90 degree turns makes it nearly impossible for the dryer to do a good job drying clothes. I own a Tjernlund LB1 dryer boost fan and it works wonderfully - a great solution to drying clothes in a reasonable amount of time with much less wear and tear on my dryer.
Here is another idea - I recently opened up my dryer to fix a problem and found that the interior exhaust pipe - the part that takes the exhaust air out of the dryer, into the vent pipe on the back of the dryer and eventually outside - had become disconnected INSIDE the dryer. The dryer itself was full of lint and the air wasn't getting out of the dryer at all. If you have this problem you'll also have a lint problem, so check this out - it would be an easy thing to fix.
Mar 01, 2010 | LG DLG5988 Gas Dryer
On autodry clothes do not fully dry
Try it with the exhaust pipe disconnected for a load, if that makes a difference, you need to have your vent pipe cleaned. Check in your exhaust pipe in the machine, too.
May 05, 2009 | Electrolux Frigidaire Affinity AGQ8700F...
Dryer taking longer to dry clothes
For a gas dryer:
Assuming the dryer is working properly and the control cycles are ok, look for things like a restricted venting system which inclides the exhaust, lint screen, etc. This would be the large pipe connected to the dryer exhaust that vents outside.
If it's an electric dryer, there could be issues with heating elements, thermostats, a control board, the timer, etc. Also check for any excessive lint build-up.
Apr 12, 2009 | Dryers
Whirlpool Dryer
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Apr 29, 2008 | Dryers
Dryers Logo
220 people viewed this question
Top Dryers Experts
