Question about Bosch HMT9626GB Microwave Oven
Samsung CM 1029 1000 Watt is not starting, although everything seems OK!
How many watts does it have
should be on the data plate inside the microwave. it may be listed K/W kilowatts.
Mar 08, 2015 | Samsung Microwave Ovens
Hello, I have an AEG microwave, 6 years old. When I turn the button to chose the cookingtime and the WATT , the display shows what I choosed so thats OK. When i then press the start button the microwave...
This can be due to wrong choice or fault in the power supply ,main board or the magnetron.
You should try with a preset selection and if the microwave works then the fault relates to correcting the power to time settings.
Check out with microwave cooking tips.
Feb 01, 2013 | AEG MC143EUX 750 Watts Microwave Oven
Cm 1929 error code e41
i there i have a samsung cm1929 microwave and it coming up with the code e41 please help thanks mike
Nov 08, 2010 | Samsung MW1080STA Microwave Oven
DCS - CMO24SS - 900 Watt - Microwave not Heating
If all appears to be running as its working but just no heat. Could be issue with magnetron. You could also have loose connections to magnetron or somewhere in high voltaged as well.
Nov 24, 2009 | DCS CMO-24-SS Convection/Microwave Oven
Power level again
It is probably a 700 watt model. Most ovens have 10 power levels, ranging from 10% to 100%. Normally you press POWER LEVEL, then press 1 for 10%, 2 for 20%, etc., then press START or COOK to cook. We could not find exact information on this model.
Mar 25, 2007 | Samsung MW4350W Microwave Oven
Bosch HMT9626GB Microwave Oven Logo
62 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
