Question about Pentair FILTER TANK BOTTOM, 48 SQFT
I have a Pantera 2 sand filter by wicor, 2nd hand. they told me it leaks abit around the top, but I could by a kit for it where do I get a kit or how do If fix it?
The plastic pipes have come unglued inside. probably from being frozen.
take apart from the top, unscrew side pipes, reglue main distributor pipe, reassemble by screwing side pipes by hand while inside main tank. the sand that is now in the pool will vacuum up and them stay in the filter where it belongs
Posted on May 09, 2011
  • 83 Answers
Depending on which model that you have, you may be able to find replacement parts online. Poolcenter.com is one place that sometimes has older parts. In fact, if you follow the link below, it will take you to a parts listing online:
http://www.poolcenter.com/parts_filter_starite_pantera.htm
However, that is for the Sta-Rite/Wicor model and may not be the one you have there. If it is not, one possible option is to email Pentair from their website. If you can take a jpeg photo of the filter, they may be able to further assist you in finding the correct parts.
Posted on Jul 02, 2009
Pantera wicor model no. P24
if not able to get seal check hardware store for oring or replace unit
Feb 09, 2014 | Hayward SAND FILTER, PRO SERIES
Pantera pool filter manual
Exactly where is the pump leaking?
If it is leaking between the wet end and the motor then you need a new shaft seal sometimes referred to as a mechanical seal.
You will need to know the brand of your pump when you start searching for the replacement.
Rod
US Parts Center
May 06, 2013 | Hayward SAND FILTER, PRO SERIES
Have a pantera p24 sand filter from wicor and the lable has gone from the control lever. I need to know what function is in each position.. filter, rinse, backwash etc.
don't know if you got it fixed or not but can give you mine....if your looking at it from the top it goes like this....in the twelve o'clock position nothing,1 o'clock is recirculate then 3 o'clock is backwash then 5 o'clock is close then 6 o' clock winterise then 7 o'clock is waste then 9 o'clock is filter then the 10 or 11 o'clock is rince. hope that helps..
Jul 15, 2011 | Wicor Industries Master Plumber Geyser...
When filtering water it is also leaking through back wash pipe it is a sand filter pantera hi-rate filter with sta-rite water flow control
Is this a multi-port valve offering back wash, no filter, rinse, etc. modes? Have you ever turned it counter clock wise? (Never turn it counter clock wise.)
You will need to remove the top and put a new gasket in the valve.
If it is Push Pull, remove the two screws at the top and pull the assembly out. Remove and replace all "O" rings. Lube with silicone grease for pools and reassemble.
I think this will fis you up.
Thanks for your question today.
Jan 30, 2011 | Sta Rite Pool & Spa
Labels Gone
I also have the same problem with the label on my filter. My pool dealership said I would need deal with Wicor directly. I see two other people with the same problem, however, neither has been responded to. It is VERY difficult to run your pool properly if you don't have your control lever labeled. An immediate response would be greatly appreciated.
Apr 23, 2010 | Wicor Industries Master Plumber Geyser...
Older Polaris doesn't sweep
If the unit travels normally and picks up debris as it should,there may be a problem with a feed hose inside . Separate the haed shell and inspect. often the plastic clamps finally give out and allow hose to pop off. Also check inner hoses for any swelling and possible slits.If the unit doesn't act in a friendly way then you have water supply issues and/or inadequate water pressure to unit. Check stream from wall with unit disconnected.
Apr 06, 2009 | Polaris 380 In Ground Pool Cleaner
Pentair FILTER TANK BOTTOM, 48 SQFT Logo
1,102 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
