Why is my top load washer leaking machine oil into the washtub?
  • 11,896 Answers
One of the seals probably the one on bottom of agitator that attaches to bearings or coupler is leaking.
Posted on Jul 02, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Why is it displaying f2 code and will not drain?
The F2 fault code indicates a problem with the washer's drain system, and you must troubleshoot the problem to determine how to fix the washer and clear the code.
Clogged Drain Hose The drain hose on a Kenmore washer should remain free of obstructions so the water drains from the washtub. the drain hose behind the washer can impede the flow of water from the washer. A drain hose inserted more than 4 1/2 inches into a floor or wall standpipe drain system can cause the water to siphon back into the washtub.
Stuck Water-Level Pressure Switch Your Kenmore washer uses a water-level pressure switch in the control panel to detect the level of water inside the washtub. You can find the pressure switch behind the control panel in top-load models or attached to the inside wall of front-load models. The round switch is approximately 3 inches in diameter with a clear or black plastic tube connected to the bottom or side of the switch. The tube runs from the pressure switch to the exterior washtub. As the water fills the washtub, it changes the air pressure inside the tube and lets the switch know when the water has reached a predetermined level. A stuck contact on the pressure switch can stop the advancement of the wash cycle and keep the water from draining. A few taps on the top of the switch with a screwdriver handle can release the contact and fix the problem causing the F2 error code.
Jun 12, 2015 | Washing Machines
Agitator and washtub don't turn
sounds like the drive belt remove the front panel and look under the wash tub for a broken belt
Dec 18, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
My washtub makes a lot of noise in the spin cycle its banging against the walls of the washing machine....I can move washtub from side to side easily with my hand
there are shocks inside the machine that damper the vibration, one or more has failed, they can be replaced if you are a good do it your self er, if u have to pay to fix it replace not worth the cost of repair. the repair requires taking off all the panels to access the inside. and check cost of dampers and compare to cost versus replacement
Apr 23, 2010 | Maytag PAV3240A Top Load Washer
My admiral leaks as soon as the water turns on, it appears to be coming out of the housing unit for the hoses rather then the tub or the hoses.
There are a few places that a washer could be leaking:
1) the water valve itself, it may be cracked (most are plastic), or the hose connecting it to the spout may be loose.
2) the hose from the water valve to the spout (as above) could be loose from spout or water valve. It also may be cracked or have a cut in it from wear on other parts.
3) the spout may be damaged or loose from the back plate making it misaligned so the water spills over the side of the tub.
4) the washtub may be missing a spring that keeps it centered in the machine causing the fill spout to spray water over the side of the washtub.
5) There may be a leak in the tub, pump, hoses for the pump (not likely since when it leaks)
That's all that there is to leak when it does not leak all the time. (if it were all the time you could throw the supply hoses and valves in the mix.
Hope that helps
Oct 31, 2009 | Admiral AW22 Top Load Washer
No Agitation
Ether the belt is broken or the transmission has failed.
Jun 18, 2009 | Estate ETW4400TQ Top Load Washer / Dryer
Oil in washtub
needs a transmission uppper seal is leaking very expensive suggest you but a whirlpool or roper to avoid this problem in the future
May 30, 2009 | GE WDSR2080D Top Load Washer
Oil leaked into the washing machine tub.
there is no green oil in washer ..ck/detergent/fabric softner bottle close for leaks oil leak would usually be brown or almost black in color ck around top edge of washer tub for deposits of softner/detergent
Jun 17, 2008 | GE WBSR3140DW Top Load Washer
Water leak fromwasher during drain cykle
Removing the front panel:
1. Disconnect the washer from the electrical supply
and release the console.
2. Releasethe bellows fromthe front panel and remove
the (2) screws holding the door safety switch
assembly to the front panel.
3. On select models, disconnect the wires from the
light switch.
4. Raise the front of the washer and remove the (4)
screws securing the front panel to the washer base.
Feb 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
271 people viewed this question
Top Washing Machines Experts
