Question about Dell Dimension 2350 PC Desktop
My CPU fan for my Dell Dimension 2350 has stopped turning!
The Cpu fan for my Dell Dimension 2350 has stopped spinning. Now every time I try to turn the PC on, it turns off after about 5 mins.
Does the fan simply need cleaning?
How do I go about replacing the fan??
  • Dell Master
  • 1,684 Answers
If your fan is not turning at all then it is probably dead, the bearings are likely clogged with dust and such. The PC is shutting off because of heat buildup on the processor chip. You need to do an Ebay search for your model and order a fan right away. Continued running of your sysem without a fan will kill the processor and motherboard. You should be able to get a replacement fan for your computer for less than $15 including shipping. Your local computer store may have one to fit your system but they may charge more for it. To change the fan is very easy, the left side of the case will come off your system, right under the power supply is the processor and heatsink and the fan. Disconnect the old fan and reconnect the new unit.
I hope this helps, if so please rate my solution
Buddy
Corporate Computer
WWW.CCL-LA.COM
Posted on Jul 02, 2009
Cpu fan can't run on dell dimension
You can clean or replace the fan.
Get the manual from www.dell.com/support
You can download it free and look up the fan repair instructions.
Hope this helps.
Mar 05, 2012 | Dell Dimension 2350 PC Desktop
When i turn on my computer is said cpu fan is not detected
Dear dao,
It seems to be your PC Fan is faulty.So to confirm this remove the side panel of your pc cabinet and then turn on your system,and see weather CPU fan is rotating or not. Let me know the result.
Feb 18, 2011 | Dell Dimension 2350 PC Desktop
Every time i turn on computer is said cpu fan is not detected
The fan on the CPU is not running fast enough or it is not running at all replace it before it cooks the CPU and the motherboard.
It states cpu fan not on
Hope you can open the CPU and check the CPU fan. Try unplugging the fan power cable on motherboard and inseting again.
If it doesnt solve it, take out the fan (attached to the top of heat sink. Dont take out heat sink) and try with a battery of some 6 volt. Red +ve Black -ve. If it doesnt run, you need to replace that fan.
Aug 08, 2010 | Dell Dimension 2350 PC Desktop
The dell dimentions 2350
Ensure that both the case fan and CPU fan are dust free and spinning. I think it could be overheating and then shutting itself off to prevent damage
Feb 01, 2010 | Dell Dimension 2350 PC Desktop
How to remove and replace cpu for dell dimension desktop 2350
the cpu is a intel remove and replace a cpu is very easy
This link may help it is the rong model but dictates the process
You will need to open the case and be carefull of statick
ab510a2.jpg look for the cpu heatsink
Remove the fan unscrwe on the top
then remove the silver part this is held on with clips
gentley remove the cpu and replace new one THE RIGTH WAY look for the corners on the cpu to mach up on the board
Nov 24, 2009 | Dell Dimension 2350 PC Desktop
Dell dimension 2350 cpu fan failure
i can help with the mouse & keyboard.
go into the bios on boot screen you press DEL i think then activate the USB mouse & keyboard option then save & exit.
there will be settings for the cpu fan in there somewhere but i can't remember where sorry.
Aug 16, 2009 | Dell Dimension 2350 PC Desktop
Motherboard powers up for 2 seconds then down on dell dimension 2350 fans start then immediately go down...pulled power supply and replaced but still same problem
if you have the knowhow, do the following
remove your CPU fan which comes with a heatsink,
then apply some heat sink compound paste on your heatsink where the heatsink makes contact with your CPU.
then connect your heatsink and fan, lock them into position and turn on your PC.
helpful? if not give me a reply to give you other ideas.
Mar 23, 2009 | Dell Computers & Internet
Dell dimension 2350 shuts off after a few minutes
Definitely check the power supply fan and the CPU fan for dust. Overheating could be the culprit, good luck.
Mar 18, 2009 | Dell Dimension 2350 PC Desktop
CPU fan not detected.....
The cpu fan has a three wire connector that connects to the mother board. Usually located to the right & up from the cpu. If yours is connected currently the wires may be miss aligned. From left to right the pins are: first pin ground/Black; middle pin 12v./Red & last pin rotation/Blue. There may be a bios update that address this issue. Dell does not give up information easly.
Jan 13, 2008 | Dell Dimension 2350 PC Desktop
Dell Dimension 2350 PC Desktop Logo
238 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
