Question about Hitachi PJTX100 Multimedia Projector
Blue patch I have a blue patch that shows up on the left side of my screen. The shape changes over time but it's always on the left side.
  • 7 more comments
  • earflaps Nov 13, 2007
    I have the same thing...a purplish patch on the right side of my screen.
  • Anonymous Dec 03, 2007
    I have exactly the same problem. Always on the left side and usually at the bottom. Shape of blue image changes. Is this able to be repaired? I'm only on my 2nd bulb.
  • packerfan4 Dec 06, 2007
    mine started out as little dots now huge patches bottom left side
  • Anonymous Dec 12, 2007
    I have a blue line along the left side of the screan
  • Obsidian Dec 23, 2007
    I have exactly the same problem , blue patch bottom left, and definitely varies in size. this fix at the bottom , is this something i can do? , if so are there any slightly more detailed instructions?
  • Master66 Dec 25, 2007
    Same problem and factory defaults and color/contrast changes does not make it go away. What exactly can I do to remove this image from the picture??
  • jimalvey Jan 04, 2008
    blue patch in middle. I changed the bulb - thinking that was the problem, but the blue is still there.
  • pharrop Jul 20, 2008
    I experience the same condition with a top right Blue streak, I tried replacing the bulb but no change
  • musty1 Jul 29, 2008
    I have a hitachi pj-tx 100 and at about 2000 hrs use (just out of warranty) a blue patch appeared all down the right side of the screen and across the bottom. I clean the filter regularly and have the fan set on high. Last night I watched the screen completely fill with a cappilary like motion of black lines! what is going on, I thought these were a top of the line projector??
    Problem Solver:
  • 17 Answers
You didn't state how many hours are on the unit, but I'm guessing close to 3,000 hours, that is when most brands have LCD panel failures, due to the heat over time the coating on the lcd panels burns off, the panels start to burn up, and it gets worse with time, and you notice it more when you put a fresh bright lamp in. if it is low hours then you could have a bad lamp, that casts a bad tint, but it sounds like fried LcD panels, a sure way to tell, is put up a white back-ground screen and see if you see discolored "BLOB" in the center of the screen.
keeping the filters clean, and the projector cool is the best way to prevent this.
Posted on Jul 17, 2008
  • 520 Answers
Its an obstruction on reflectors beyond lamp.remove lamp,clean it anyway(dry cloth)get hair dryer ,blow into casing to remove residue,re fit lamp.not the the best remedy but the other way requires disassemble and voids warranty but this disperses build up of dust
Posted on Feb 23, 2008
I had the same problem with my Hitachi PJTX100. I discovered that there was considerable dust build-up inside the unit, causing insufficient venting of heat which then damaged the color prism/filter. It was close enough in time to the warranty for Hitachi to cover parts replacement (approximately $1,600). Since the repair, I regularly vacuum not only the outer cover but also the inner air filter that easily snaps on and off.
Posted on Jan 17, 2008
    Genius:
  • 1,153 Answers
Requesting projector status (Get command)
(1) Send the request code Header + Command data (‘02H’+‘00H’+ type (2 bytes)+
‘00H’+‘00H’) from the computer to the projector.
(2) The projector returns the response code ‘1DH’+ data (2 bytes) to the computer.
Changing the projector settings (Set command)
(1) Send the setting code Header + Command data (‘01H’+‘00H’+ type (2 bytes) +
setting code (2 bytes)) from the computer to the projector.
(2) The projector changes the setting based on the above setting code.
(3) The projector returns the response code ‘06H’ to the computer.
Using the projector default settings (Reset Command)
(1) The computer sends the default setting code Header + Command data (‘06H’+
‘00H’+ type (2 bytes) +‘00H’+‘00H’) to the projector.
(2) The projector changes the specified setting to the default value.
Increasing the projector setting value (Increment command)
(1) The computer sends the increment code Header + Command data (‘04H’+
(2) The projector in creases the setting value on the above setting code.
Decreasing the projector setting value (Decrement command)
(1) The computer sends the decrement code Header + Command data (‘05H’+
‘00H’+ type (2 bytes) +‘00H’ + ‘00H’) to the projector.
(2) The projector decreases the setting value on the above setting code.
When the projector cannot understand the received command
When the projector cannot understand the received command, the error code ‘15H’
is sent back to the computer.
Sometimes the projector cannot properly receive the command. In such a
case, the command is not executed and the error code ‘15H’ is sent back to the
computer. If this error code is returned, send the same command again.
When the projector cannot execute the received command.
When the projector cannot execute the received command, the error code ‘1cH’
+ ‘xxxxH’ is sent back to the computer. When the data length is greater than
indicated by the data length code, the projector ignore the excess data code.
Conversely when the data length is shorter than indicated by the data length
code, an error code will be returned to the computer.
Posted on Nov 26, 2007
I have a Panasonic PT-52LCX15. 3 months ago I changed the lamp and now I have a blue -ish line along the left side of the screen?????
This sounds like a damaged optical light engine.
This set uses a L shaped engine--the lamp shines into it and heat from the lamp can cause the prisms/lens inside to warp slightly(hint: blue is the first part of the engine to get the light from the lamp--usually shows first).
If no extended warranty it is going to be an expensive repair--the engine is the most expensive part of the set.
Let me know with a comment here if you have questions.
SD TECH
Apr 13, 2011 | Panasonic PT-52DL52 52" Rear Projection...
MFC-7840W Printer Brother, we have replaced the toner many times and the printer always shows the message on its screen: low toner, and after that shows: toner life end, what we can do, because this is the...
Open the front cover. Remove the drum and toner. Remove the toner from the drum by pressing and holding the green/blue tab on the right side then lift the toner out. Shake the toner side to side for 6 times, and on the drum unit slide the blue/green tab on the far left side from left to right for 6 times also. reinstall the toner back to the drum unit. reinstall drum and toner back to the machine. Close the front cover. The display should show the date and time.
Hope this will help.
Mar 25, 2011 | Brother MFC 7840W Printer
Can`t figure out keyboard on acer aspire one, blue numbers and letters etc Karl
blue number etc are functions that are connected to the blue fn button in the left hand corner.
press and hold the blue fn button and at the some time one of the other buttons.
eg volume + or - for volume up and down or the moon shape for hibernate, or the sun to change the screen brightness,antenna button to switch on and of your bluetoot or wifi, or the screen button to switch on and off your external monitor port on the back etc. the blue number are your numeric keypad like on a normal keyboard this can be used in the same way by holding the blue fn button down at the same time.
I hope this was helpful
Dec 12, 2010 | Acer NSK8458AN Keyboard
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Blue ghost image on left side of screen
The Optical Block Assy would have to be replaced, same part that causes Blue Dots, not considered to be user replaceable.
Mar 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
3LCD Projection TV 2.5 years old displaying blue hue/blobs
I would first try a new lamp. If the reflector portion of the lamp has any defects, it could show up this way as the light would not be uniform. The next possibility is a defective light engine. The engine portion if not field repairable and would need to be replaced. Try the lamp first and let us know what happens.
Dan
Jan 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
HDTV is getting blue dots and the right side has turned blue
These issues are problems in the light engine (optics block)
the dots are called "starfield" and the geometric is "roadmap"
replacing the light engine will fix the issue. for awhile, sony was extending the warrany on the engine for these issues only, but that may have expired.
part # A-1606-008-A
Nov 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Nov 13, 2008 | Televison & Video
Blue patch on left side of screen
I had the same problem with my Hitachi PJTX100. I discovered that there was considerable dust build-up inside the unit, causing insufficient venting of heat which then damaged the color prism/filter. It was close enough in time to the warranty for Hitachi to cover parts replacement (approximately $1,600). Since the repair, the blue patch is gone. I also regularly vacuum not only the outer cover but also the inner air filter that easily snaps on and off.
Dec 27, 2007 | Hitachi PJTX100 Multimedia Projector
Screen has developed several patches but only on blue images
drop it like its hot when your wife is away bang your dog
Aug 17, 2007 | Pioneer PDP-505CMX 50 in. Plasma...
Hitachi PJTX100 Multimedia Projector Logo
697 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
