Question about Saniflo & Saniplus& Macerator Pump
My macerator turns off and stops working for 10 - 15 minutes
We have a macerator and for the most part it has been fine, however since we had a new flatmate move in who has longer showers it makes a funny noise, then stops working and all the water gets blocked up. It won’t kick back in for another 10-15 minutes, at which point all the water will drain and we can use the shower and sink again. Does anyone know why this happens? Do we need to get a plumber to come and take out the macerator to see if something is blocking it or is this normal? Many thanks for your help.
  • 24 Answers
The macerator is over heating.check the maintenance opening and clean it ,but you may need a more powerful macerator,some are made only for flushing systems (as in toilets) a pro-longed use may be making it overheat.. good luck
Posted on Jul 08, 2009
Water keeps flowing back into the macerator
There should be a check valve installed in the discharge elbow, check if the check valve is installed or it might just be stuck open so when waste water is pumped out, it slowly drains back into the unit creating water pressure that is making it kick on and off.
Oct 07, 2012 | Saniflo & Saniplus& Macerator Pump
Whining noise after the flush is filled and the noise keeps on but if the macerator is given a gentle kick the noise stops! Do I need a new Macerator?
sounds like there could be a blockage inside which is effecting the pump or the float switch look on the saniflo website for instructions how to clean etc or phone there tec department
Dec 09, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a saniplus toilet, the macerating unit runs about every 2 minutes for 1-2 seconds at a time. I'ver replaced the flapper and even turned off the water to the unit and stopped using it, but it keeps...
Water pressure makes the unit kick on and off. Water could be leaking from the toilet tank into the bowl and from bowl into the pump. Or the check valve inside the discharge elbow (on top of the lid) may not be sitting properly or is being obstructed causing waste water to leak inside the pump, creating enough water pressure to make the unit kick on and off by itself.
Sep 06, 2010 | Saniflo & Saniplus& Macerator Pump
Macerator overflows
Check the vent pipe, most of the Saniflo products require an 1 1/2" vent pipe vented to the open air for air flow purposes. Air must flow in and out of the vent pipe at all times.
Jun 28, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
My macerator turns on for a few seconds every couple of minutes, does anyone know why and how to cure it?
may be your overflow on your toilet cistern... check its shutting off the fill valve and not dripping into the overflow.
Dec 30, 2009 | Saniflo & Saniplus& Macerator Pump
This was just installed. When it is flushed the
If there is a air emiten valve on vent ? Remove it than try to see if it works properly. If this works you will need pipe vent outside
Dec 21, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Macerator
unfortunately saniflo - nor any one else publishes a saniflo repair manual. You can get tips online - but thats as far as it goes.
Dec 10, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a 3 year old Sanivite 3 macerator that has stopped pumping. It is used under the kitchen sink for removing water and soft food waste. Yesterday I removed the unit and cleaned the inside which was...
if the unit is properly clean and you have checked the fuse - then i suggest it is the microswitch that needs replacing. these tend to go (break) within 5 years on the sanivite 3 models. If not the swich then it could be the capacitor (try this first - although as the swich is located next to the capacitor you can test this for operation at the same time). if none of this works then its time for a new unit.
Nov 09, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo & Saniplus& Macerator Pump  Logo
588 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
