My Maytag washer, Model A390, spins but does not agitat. The belts feel very loose even when I hold the flywheel.
  • 10,865 Answers
If your washer doesn't agitate, check these
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Posted on Jul 02, 2009
Loose belts on Maytag Washer LAT2300AAE
It is normal for the belts on this model to be loose. Normally the noise that you are hearing is either the damper (a white plastic type material,comes in a kit) or the pump making the noise. Take the belt off the pump and put it into a spin cycle and see if you hear it. If so ck the tub bearing for rust or leaking and the damper for wear. If you don't here it, ck the pump.
Mar 04, 2013 | Maytag MAV4755A Top Load Washer
Will not agitate, motor runs ok and will spin dry ok.installed a slightly shorter drive belt on and it would agitate but not spin dry, I have a new bet kit ordered is there something else to check, th
see this causes and fix it. God bless you
First you will need to identify if you have a direct drive type or a belt drive. The later is obvious if you have belts under your machine it is a belt drive, if not it is a direct drive. Also there are 2 basic agitator types with some variances among them. The 2 piece and the single.
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitaor dogs follow video.
Agitator Coupling / Spline
The other type depending on age of your machine use a spline. Newer GE types have a coupling that gets stripped out and the older GE type has a spline directly on the agitater that gets stripped out. You will need to remove the agitator. The dispenser usually pulls right out. This will give you access to the bolt that holds the agitater down. Remove the bolt, then place your fingers under the agitator and pull up. This can take some force. A belt slid under the agitater can also work. Once off you will see if it is stripped or not.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Oct 02, 2012 | Maytag Washing Machines
Model LSE1000 - The washer is getting old and not spinning the clothes as dry as it used too. Am I looking at replacing belts, pumps or cleaning out something that may be causing this problem. The washer...
NEED TO KNOW NAME BRAIND IF WHILPOOL HOW OLD IF MAYTAG REPLACE BELT SAME WITH GE WITH WHILPOOL NEED MOR INFO TO HELP LIKE IS IT SPINING AT ALL OR SLOW IF SLOW MAY BE YOUR CLUTCH OR DRIVE BLOCK IF NOT AT ALL WILL IT AGITAT IF NOT DRIVE COUPLER IN BETREEN PUMP AND MOTOR
Apr 03, 2010 | Washing Machines
When it spin a burning rubber smell is very strong and the wash is not ready for the dryer because it is still very wet. My washer is Maytag model LA810 series 01 serial# 013122 LR Ihave changed the belt...
New washer? probably not, but you very well may need a new tensioner pully spring.
Either the new belt is the wrong size, or it is installed improperly, or the tensioner is not providing enough tension to keep the belt tight. Make sure the moving parts are oiled. Sticking parts can also prevent the tensioner from pulling properly.
Oct 03, 2009 | Washing Machines
Help with agitater
http://www.pcappliancerepair.com/model-display.php This site shows the parts holding your agitator. It looks like there is a nut that can come off. There are also repair manuals available.
May 02, 2009 | GE WDSR2080D Top Load Washer
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer will not agitate but will spin
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Oct 21, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
