My car Air Conditioner is not blowing cool air.
The heater work's fine. I would like to know how I go about checking for a short in the wire, I don't think any fire is reaching the compressor.
1999 Dodge Intrepid
3.2
    Problem Solver:
I'd check the comppressor's relay, is locate at relay box and probally is one of the big relay you have in the car ,and fuses but and sure if the relay.
Posted on Jul 02, 2009
    Scholar:
  • 106 Answers
Bonjouir, kindly allow me, V, to dust a little of my ideas on this matters. The AC in cars work based on the same principle like refrigirators, the Expand and cool a coolant chemical, known as Freon. Its volume expands and compresses perpetually, this creates a drastic thermal change. But anyway, he.heheh....hehe. The AC is not working, that's what we should focus on. The AC's coolant most likely is detoriant. It can be replaced easily, you can cleanse the previous coolant, make sure to refer to Dealer, or Car manual, or even mechanic. They will tell you exactly which product to buy for your Car's System. After the Flush, (this is a process used to completely remove any residues of the previous chemicals, often uses anothe chemical as well) process, you can install the new one and it should work. You can google: "Flush Process for Cars" and Wala...lOl :)
Thankyou,
V :)
Why would my combo A/C - Heater unit not blow air while heating or cooling is selected but will blow air just fine when set to "fan only"?
Sounds like wiring issue to me. I've delt with units like this and there is a wire lead for fan only and a separate one to run the fan when the unit is cooling or heating. I'm only speculating here but I would bet money that this was improperly installed.
Dont get discouraged though because it sounds like its working (for the most part) if you feel up to the task find the manual and check your connections. Otherwise hire a professional.
Sep 20, 2014 | Heating & Cooling
2008 Jeep Liberty-My heater was barely warm-blowing fine tho. Was told I had a plugged heater core and needed a new one. Had a new heater core put in and then my air conditioner stopped blowing cold air....
I woild be checking the vent controls as if the ac is working and the core was blocked then the air would be cool when the heat was selected but not changing Fixing the heater has resulted in a /c not being good enough to cool the air if the vent is not properly selecting. The point is that if the vent selection is not working properly (vacuum hoses) then the 2 faults will be related.
Oct 24, 2013 | Jeep Liberty Cars & Trucks
Air conditioner blows the fuse
SOUNDS LIKE YOU HAVE A SHORT IN THE WIRING BETWEEN THE FUSE AND THE AC PANEL, USE A CONTINUITY TESTER TO CHECK FOR CONTINUITY , IF THAT FAILS OR IS OK THEN CHECK ALL RELATED RELAYS IT MAY JUST BE THAT YOUR AC NEEDS RE GASSING?
Sep 02, 2012 | 1997 Land Rover Discovery
Why is ge ajes12dcc 11600/11400 window air condition/heater combo blowing cold air for heat the air conditioner is working fine but the heater is blowing out cold air
Hi, it sounds to me like your reversing valve is not switching the flow of freon over to heat, stuck in cooling. The valve is located near the compressor, it has a 24 volt coil on it. If you unplug it, it should switch the valve into heat. If not, the valve is probably froze stuck, and will need to be replaced. Something a service tech would have to do.
Shastalaker7
Nov 06, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
I keep blowing the control transformer when I turn on the A/C. The system works fine when I turn on the heater. When I try to turn on A/c nothing turns on before control transformer blows.Jim...
First thing I would recommend is to go to the closest auto parts store and get an inline car fuse folder and some 5 amp fuses. Connect this to wire that comes off the transformer and goes to R. That way you will only blow fuses instead of transformers.
I will assume this system isn't a heat pump since it runs fine in heat mode. If it is, please let me know. Also, I will assume there is no circuit board outside, but let me know if there's one.
Go out to the condenser and remove the Y wire from the contactor, then try the system in cool mode. If the fuse blows, you have a short in the low voltage wire between the air handler and condenser and will need to find it, cut it out, then re-splice. If the fuse doesn't blow, you will likely need a new contactor.
Mar 23, 2010 | Ruud UBHC Air Conditioner
1999 Volvo S70 heater and defroster blowing "fog"
suspect leaking heater core.check coolant level.
Sep 29, 2009 | 2000 Volvo S40
Air conditioner blows hot air inadvertantly.
possibl ac compressor clutch problem,cooling fan at rad not working so ac goes into high press mode and turns off(so it doesn,t blow system apart,built in safety)not enough r134 in system(low charge)
Sep 19, 2009 | 1997 Chrysler Concorde
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
Danby DPAC10061 portable air conditioner problem
you may have a factory defective unit that is not turning off the anti-frost heating coil (I have assumed yours contains this item based on your problem description). I would trade it in for a new unit, again assuming you have a warranty or the store offers a good in-store return policy. If this plan bombs, then open the unit and find the heating coil near the cool side of the radiator fins. then disconnect the power wires to the heater and prevent electrical short to wires with quality electrical tape.
Jul 06, 2007 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
