I have a ford galaxy 2.3 zetech 2000 X,when i turn the aircon on the fan is not turning for the aircon to work
  • 400 Answers
Try to check the fuses and fan relay.
Posted on Jul 02, 2009
I have a Ford Falcon FG G6E and the aircon fan stopped working but the aircon does work but the fan is not.
Either ac fan relay or fan itself. Not sure if there is a maxi fuse that covers the relay circuit.
Dec 19, 2017 | Ford Cars & Trucks
Idling drops when aircon is turned on
that is normal AC uses the power from the engine to work.
Feb 03, 2014 | Cars & Trucks
What type of refrigerant does a 1990 Ford Ranger use?
there are only two types of refrigerant (or normally called as freon): R12 and R134. R12 is designed for car model 2000 and below. though, some old car compressors can accomodate R134 provided that you change your auxillary fan (fan for your aircon condenser) since R134 is hotter than R12. Ask an aircon technician if your compressor can be charged with R134.
Most of the countries now ban the use of R12 since it is more harmful to our ozone.
Aug 05, 2011 | 1990 Ford F150
The cabin blower fan only works in position 3, as does aircon. Move to any other number & the fan, together with aircon if on, stop.
Sounds like it's the blower motor resistor. Most likely this is the problem in most cases but the control could be bad but doubt it. I hope this helps and good luck.
Jul 27, 2011 | 2000 Ford Focus
What motors are interchangeable with a 1998 ford escort
you can fit a zvh engine which is a 1800cc zetech block with a 1600cc rs turbo head bolted on and will fir in without too much trouble or a standard 1800cc zetech engine will go in
let me know if this helps
cheers
Feb 19, 2010 | 1998 Ford Escort
Just had aircon regassed on 2002 focus bowers working aircon light on but not cold at all
If freon was added because of a leak, it could have leaked down again. If freon levels are too low, the compressor will not switch on. Check to see if the center (it is connected to the compressor shaft) of the compressor pulley is turning.
Sep 02, 2009 | 2000 Ford Focus
Aircon not operating on tickover
check that cooling fan is coming on when ac is turned on
Aug 06, 2009 | 2000 Audi A6
Aircon works but blows hot air
I had the same problem (during Summer!!) - If you take the Fan/A.C/Temp Control panel off, you'll probably find the plastic bracket that the control cable mounts to, is broken. I just used 3 zip-ties to hold everything in place. 30 minutes work, & 50c parts!! No problems since.
Nov 12, 2008 | 2001 Daewoo Nubira
Fan not turning off
You say that the air con is not cold, i think the problem would be the aircon will need regasing, if the gas has escaped from the system, the temperature in the aircon system will always be warm so the fan will continue working attempting to cool it down. It will need checking for leaks, most companies that recharge the system check the whole system for leaks first before refilling the system. If its the engine cooling fan it could be the thermo switch that is faulty,the way to check that is when the engine is cold disconnect the wires from the switch and put an ohms meter across the swith it sould not give any reading, it will only show a reading when the engine reaches operating temparature. hope that helps. regards Richard
Nov 01, 2008 | 2000 Jeep Grand Cherokee
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
