Rank: Guru
Rating: 85%, 331 votes
The connection unsecured means anyone can connect to the wireless router just by scanning without giving any password.....
Inorder to make it secure there are three dufferent waysm they are explained as follows...
1} DISABLING SSID BROADCAST
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
Note: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4).
Accessing the Router's Web-Based Setup Page
Step 1:
Open a web browser such as
Internet Explorer.
Step 2:
Go to the
Address bar and enter your router's
IP Address ("192.168.15.1" is the default IP of most Linksys VOIP routers) then press
[Enter]. or
192.168.0.1
Note: If the IP address of the router has been changed, type the router's IP address in the
Address bar instead.
The router's IP address can be changed by:
Running the router's setup CD.
Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
Check the router's IP address.
Press the Reset button at the back of the router for 30 seconds.
Note: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.15.1" and the password will be "admin" after resetting.
Step 3:
A new window will prompt for a
User name and
Password. Type "admin" for
User name and
Password ("admin" is the default user name password), then click
OK.
Note: If the password of the router has been changed, type the router's new password in the
Password field instead.
The router's password can be changed by:
If you are encountering problems access the router's web-based setup page, click
Disabling SSID Broadcast
Step 1:Access the router's web-based setup page. For instructions, click
here.
Step 2:When the router's web-based setup page appears, click
Wireless then look for
Wireless SSID Broadcast and select
Disable.
Step 3:
Click
Step 4:Reconnect to your wireless network by creating a profile on the wireless computer's configuration utility.
If this is done you have to manually, type the SSID to connect to the network other people cant see the network..
2}USING ENCRYPTION KEYS
In the WIRELESS SECURITY tab in the router page, you can enable either WEP(Older form of security ) or WPA newer onr... Enabling these two things will ask user to set password, which may be asked while connecting to the router
These are the way to make the connection secure
ENJOY RATE THIS SOLUTION!
RNJ VINOD KUMAR
