2006 Kia Spectra EX Logo
J
Jim Mantooth Posted on Sep 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What steps are necessary to remove timing cover on Kia Spectra 2006
Ronnie Smith
Level 2:
Habit-Forming:
  • Kia Expert 77 Answers
  • Posted on Apr 24, 2015
Ronnie Smith
Kia Expert
Level 2:
Habit-Forming:
Answers
77
Questions
0
Helped
63396
Points
306
I hope this diagram is helpful.
what steps are necessary to remove timing cover on - 25050024-ir03o0ur3ff3pxc4zrfsqvc4-3-0.jpg
5 Related Answers
turboKia
Greg
  • 55 Answers
  • Posted on Aug 02, 2009
SOURCE: having problem changing rear brake pads on 2006 kia spectra
yes ... its a tool that you can buy at any well stocked auto parts store. Its cubed shaped, about an inch on each side, Its used to screw in the caliper piston
turboKia
Greg
  • 55 Answers
  • Posted on Oct 23, 2009
SOURCE: How do you replace a Drivers side headlight bulb 2006 kia spectra
Helps to remove the battery, but small ahbds can do it.
Directly behind the lens is a big round cap ... twist it off. The bulb is held in place with a spring that locks in to a notch in the holder. When handling the new bulb, don't touch the glass. The oil from your skin will cause it to shatter when turned on.
roniecon
Ronny Bennett Sr.
  • 6988 Answers
  • Posted on Apr 20, 2010
SOURCE: 2006 Kia Spectra 5 rear brake disc replacement
One side,turns right,and push in slightly,and the other side turns left,to retract.
Anonymous
  • 3092 Answers
  • Posted on Jul 23, 2010
SOURCE: timing belt diagram for a 2001 kia spectra 16 v
Hope this helps you.
Testimonial: "Wow that was a fast response. Thank you very much and have a wonderful day!!"
Anonymous
  • 3 Answers
  • Posted on Nov 19, 2010
SOURCE: my 2006 kia spectra speedometer
2006 kia spectra speedometer not working. Try this, I just did it and it worked. Disconnect both battery cables and touch them together for about 3 seconds, then connect them back to the battery. This causes the main computer to re-load all computer programs. It worked on my kia, speedometer now working. It also worked on my 2004 Chevy Silverado to correct an AC/Heating problem just after installing a new battery. The truck blew hot and cold air at same time with only AC on.
2007 Kia Spectra. The blower and power windows won't work?
Check the fuses covering those items.
KIA Spectra (2005-2009) fuses and relays
https://fuse-box.info > kia > kia-spectra-2005-2009-fus...
Here you will find fuse box diagrams of KIA Spectra 2005, 2006, 2007, 2008 and 2009, get information about the location of the fuse panels inside the car, ...
I have a 2006 kia spectra. going down road car turns off when I push reset it runs for about 100 yards
The service and repair manual with pictures and diagram will help you step by step to locate and fix the problem and you will get the manual from the given link https://toolsnyou.com
No heat on drivers side 2006 kia spectra, heat only on drivers side
Begin with a check the relevant fuse Driver or Passenger if that model has separate fuse (15/20A) see fuse box cover and always use the right fuse rating
Is it necessary to remove timing belt on 2005 Kia Spectra to change water pump
It is necessary to remove the timing belt to change the pump. Take the opportunity to put on a new belt while you're at it. Cam alignment is fairly easy. Look at
How to Replace the Timing Belt on 2005 KIA Spectra eHow
How do I change the headlight on a 2006 Kia Spectra?
Well, if it's the driver side (usually battery is on this side) - remove the battery. You should see the backing of the head light casing (two - three prong wiring harness/ may have two if brights are a seperate bulb). If only one, unscrew this couteclock wise, pull out old bulb, and insert new. Installation is reverse of removal.
Same with passenger side (remove anything that may be covering access to cover backing).
Please let me know if you need any further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
2006 KIA Spectra. AM radio sparatically works.
you will need to send it out for repair or its NEW radio time. I would recomend a NEW radio, repairs may be 150-200.00
Top Kia Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Kia Expert? Answer questions, earn points and help others
