Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
A
Anonymous Posted on Sep 02, 2014
How to fix a cracked frame on Sony 46 inch tv
How to fix a frame that is cracked on tv
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Sep 03, 2014
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005928
Points
237762
Contact the authorized service center for Sony.
4 Related Answers
Anonymous
  • 68 Answers
  • Posted on Nov 28, 2009
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Anonymous
  • 9 Answers
  • Posted on Dec 13, 2009
SOURCE: smashed screen on sony bravia 46 inch tv. Is a
If you have an extended warranty yes, if not...no
Anonymous
  • 844 Answers
  • Posted on Jul 28, 2011
SOURCE: Sony 46 inch LCD TV OWNERS MANUAL
Welcome to FixYa.
You can download the manual >>HERE
The Manual is in PDF format.
Thank you for using FixYa.
Have a great day.
Jas247
Testimonial: "Very impressed with the speed and accuracy of this answer, will use again. Thank You Ian "
vinceisaac
francoise cleofas
  • 2432 Answers
  • Posted on Aug 03, 2012
SOURCE: permanent vertical line on my sony bravia 46 inch LED TV
tried to re seat the cable at the t-con board which may have loose contact. if can not get with re seating, the t-con board has problem.
HALLO FRIENDS I HAVE SONY BRAVIA TV I HAVE TO REPLACE TCON BOARD IN 32" INCH TV I HAVE IN SPARE 46" INCH TV TCON BOARD SO CAN I REPLACE TO 32" INCH TV BOTH TCON BOARD NUMBER IS SAME ESL_C2LV0.5
but it have a memory ic means panel flash both are different programmes so panel could noy identified so replace the flash from 32 t-con and put to 46 t -con
How to fix a Sony Bravia KDL-46HX800 cracked screen with compatiple screen
You need a original replace screen, the compatible screen may not work.
Can you still get most parts for 57s500 like blubs etc.,what would be a good price for used tv it works good ,thanks for your help
Yes,very limited parts left for old design DLP tvs.Tries websites Ebay.com or Amazon.com to buy a used LCD tv.Like a Samsung have a good priced for used LCD tv around $700-750 for a "46 inches.Cosmaticly probally have some scratches,dents or may a crack on it out bazel frame,but the Tv LCD screen 100% good and it electronic circuitries boards too.
1helpful
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
2helpful
Just hung sony 46''flat screen tilts slightly measurements =
this is quite common on older houses/buildings and on occasion newer ones aswell, when a house is built a decent carpenter keeps his building fairly level, usually within 1/16th of an inch, but there are times when this exceeds 1/16th of an inch, personally i'v seen houses being built where the whole foudation is off 1/2 inch or more end to end, and on older buildings as time goes by the foundation "settles" into the ground, depending what it was built on the whole building could settle further on one end of the house than the other, this can cause cracks to form in foundations. So if your tv is "level" (be sure to try another level) and your measurments are out, this usually means your house or building isn't level or the surface which you are measuring from isn't level. But be sure to try 2 or more levels to ensure the TV is in fact "level", hope this helps.
Sony 52 inch projection Screen keeps shutting off.
not if it keeps repeating the same cycle over and over..it cost 300 once and if you have it fixed again thats another 300 and if it happens again so on and so on....
Tv goes off then red blinking light comes on
Hello it is the bulb the bulb's on the Rear projection tv are ****. Buy  new tv cause it costs alot to have these tv fixed.
Sony Bravia Kdl-40V2500
No probably not The Brd he is talking about is the BU Brd does your component video work
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
