Question about RCA DRC8300N DVD Recorder/VCR
Where can i find the firmware undate for drc 8300n
Plays dvd for a few seconds and go blank
2 Suggested Answers
SOURCE:
walesarumi
  • 6993 Answers
SOURCE: RCA DRC 8300N DVD recorder
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Posted on Mar 29, 2011
DVD8801 suddenly refuses to recognise most DVD discs
you could try to open the top cover and clean the lens with a clean soft piece of cloth and try to play before covering
Dec 16, 2011 | Philips Televison & Video
RCA DRC-285 DVD Player won't respond
hi, 2 things usually cause this kind of behaviour 1-the dvd+r have been burnt at a high speed 2-the dvd player itself is a bit old when you burn your dvd+R always burn them at a lower speed lowest if possible it'll take longer but it's well worth it and you wouldn't have a problem playing them back
Aug 22, 2007 | RCA DRC-285 DVD Player
RCA DRC 8310 - not copying from VHS to DVD. When I am playing the VHS tape I press the COPY button, it says that is copying for about 10 seconds and then stops and locks up,. If I press the RECORD...
stay with the 8x dvd (these recorders look and only work with certain types of dvds)...if your manual says maxell stay with it dont look for the brandless sale...use 8x unless your have updated your machine with new firmware from the mfr. for that 16x...are you trying to record HBO / DISNEY? its not going to be allowed on DVD...yes you can record both onto tape...but not digital..(I put all my movies onto dvd, my kids still have tape DISNEY)
hope this help
Mar 10, 2010 | RCA DRC8300N DVD Recorder/VCR
I have a sharp bd-hp21u model blu-ray disc player. I am trying to use a brand new blu-ray disc. However, it will only play for 17 seconds and goes blank. What shd I do? It will play regualr dvd's.
Verify version of the firmware, if it is older then PN9062300, you will have to upgrade it. Newer version of the firmware can be found here. For instruction on upgrade procedure refer to the owner's manual.
Dec 28, 2009 | Sharp BD-HP21U Blu-Ray Player
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
VHS -DVD RCA Flashes in blue color
if i understand your statement, you are having an issue copying either VHS to DVD or vice versa, most media today has built in copyright protection to prevent what you are trying to do, there are PC softwares to bypass these, but you will have to hook the player to your PC using a TV Tuner, or an Application called VHS to DVD or something similar,
Jun 15, 2009 | RCA DRC8030N
DVD RW DVR-K16 does not recognize blank DVD-R
I have a Pioneer DVDRW DVR-K16, in a sony dv81114Notebook. Running Windows XP. It cannot play dvd's and cd's, It will recognize blank CD-R's but when I insert a DVD-R it say's no disc installed. I have firmware version 1.15.
Nov 26, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
DVD-RW not recognising blank disk
Did you try a DVD firmware update? Some dvds need new firmware to reconize some DVDs
May 30, 2008 | Computers & Internet
Language Selection for RCA DRC 220N
try to find an original remote in a pawn shop, sometimes they have extra remotes because broken dvd players, or other reasons they only know.
May 04, 2008 | RCA DRC220N DVD Player
Model DRC 8310 RCA VCR/DVD player/recorder combo.
Did you put a splitter onto the cable signal? If yes, the signal is attenuated to much and there simply isn't enough signal for the recorder to decode. Call your cable company and request a signal amplifier be placed on your line. It's usually free.
Mar 15, 2008 | Televison & Video
RCA DRC8300N DVD Recorder/VCR Logo
70 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
