Question about Dewalt 3700 Pressure Washer
DeWalt Pressure Washer valve broken.
I removed the pump and took a look inside my non-functional pump's cylinder to check for broken parts. Sure enough, part 355 is all busted up. However, I don't know how to get to it.
Here's the schematic:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=65148&typeId=14502&documentId=35757
If anybody can help, that would be cool. Thanks.
3 Suggested Answers
  • 2527 Answers
SOURCE: How do you check oil in pump on Dewalt DPD3100
There is a little window on the side of the pump to see the oil level but thats normaly the problem None of these companys make there owen pumps or engines i owen serveral power washers if you can tell me more about the problem Iwill likely know how to fix it see who made the pump and the engine and let me know pier_j
Posted on Nov 24, 2010
mxc2
  • 146 Answers
SOURCE: Hi, My Dewalt 3100 pressure
The Dewalt 3100 came with 2 different pumps. The Blue Cat pump and the oil free pump that was made by DeWalt.
You may just have a bad Thermal relief Valve on the unit.
You can find the parts diagram at www.allpartsinc.com
Posted on Oct 01, 2011
D51822 plunger will fire (and impact wood) but will not retract enough to grab/push out a nail.
Dewalt nailers have some vinyl orings that fail. Usually found within the trigger valve, headvalve, and between the cylinder and cylinder spacer (white plastic piece). A dewalt nailer with failing orings may not leak air however. The vinyl orings tend to start to crumble and the tacky-crumbling pieces tend to create a seal. Easy way to check condition of the vinyl seals in a Dewalt is to remove the trigger valve and look at the orings on the firing pin/stem (2mmx1.5mm orings). If these two orings are soft and sticky, then orings inside of gun most likely the same. Check band on the outside of the cylinder (part # 390159-00) is what causes piston to return to top. But also check to too tight or too loose piston oring, bent shaft of driver and worn/ broken lower bumper. If all is well with internal parts and piston does not return to top, too much air is leaking past nose of gun. Oring kit sold by dewalt will contain most of the orings needed. The kit may not have orings for the trigger. You will at need two orings (2mm x 1.5mm) for the trigger valve stem or just replace the valve. Use white grease or silicone paste lube on all the orings. Good luck.
Nov 10, 2012 | Dewalt Heavy - Duty 31° Clipped Head...
Where is the spill valve on my 3.550 pressure washer
The only washer that I know that calls their pressure control valve a "spill valve" is Karcher. On their 3500 units it is under a 3/8" cap screw... which may have a marker seal of yellow or red paint on it. Removal is best acheived by removing the cap with a screw driver, note the orientation of a small bushing and remove it and then turning on the washer, with water supply attached. Be careful to hold a small bucket over the hole as the parts will pop out. The spill valve is the most common cause of the pressure not "kicking in". The first symptoms are usually a hesitation to "kick in", progressing to.... not kicking in at all. Unless the spill valve is broken at the stem, it can be "rebuilt" by replacing the orings, cleaning the housing cylinder and re-lubricating with "waterproof" grease.
Oct 21, 2012 | Karcher K2.26 Electric Power Washer
What oil to use
Your manual will say to use General pump oil GP100..or whatever DeWalt's number for that may be. See dewalt.com for their proper part number. From the pictures of that model I see on line, that is a General Pump and they have recommended Non-detergent 30w standard motor oil in the past. We like to use a non-foaming full synthetic 20-50w racing oil on these high RPM pumps.
Oct 20, 2012 | Dewalt DXPW4240 4200 PSI Direct Drive...
My twin tank 2hp comp will run but pressure wont build up pass 20 lbs.
If the motor is working OK but pressure won't go over 20psi you may have an air leak but most probably have damaged piston rings or cylinder or the valve plate is damaged. Check to make sure the tank drain valve isn't open or that you don't have leaks in any of the air lines. If that's OK, you will have to remove the head from the cylinder to check the valve plate and piston/cylinder assembly. The reeds on the valve plate should be flat and not overly discolored (black or blued) from heat. If they are they can warp or get brittle and break. Since your compressor is oil lubricated it is rare for the piston/rings/cylinder to get damaged unless it's run with no oil so check those areas for scoring or damage like broken rings. Replace whatever is damaged and keep the oil full.
Sep 18, 2012 | Dewalt D55151 2HP 4G TWIN COMPRESSOR
DeWalt D51822 Framing Nailer: Replaced the trigger valve and air is still coming from the nose of the gun. I would think no air should get past the trigger valve until pressed. What's wrong?
Dewalt framing nailers use some vinyl orings (gold or clear in color) that fail too soon in both the trigger and the cylinder spacer. Air out the nose of gun indicates air is leaking past the cylinder spacer seals (If piston is pushed down with air leak then headvalve seal is leaking (remove nails for this test)). If piston is not pushed down with leak, remove head and pull out the cylinder with cylinder spacer (white plastic). Place the cylinder on workbench with bottom up. Push down on locking ring and remove retainer to release all the other parts. Take picture or take note of parts together and as you pull them off to aid in re-assembly. You will need to replace the two orings between the white cylinder spacer and the cylinder. Order oring kit from dewalt or just purchase one ( # 141 universal oring ) and one metric oring 74.4mm x 3.1mm from hydraulic parts store. If the piston was pushed down with air leak, replace headvalve orings in the head. Good luck with your repair
Jul 05, 2012 | Dewalt Heavy - Duty 31° Clipped Head...
Dewalt emglow 2gal compressor will not reach cut out pressure
This usually means you have a problem with the piston & cylinder assembly or with the valve plate. If the piston ring or cylinder is damaged, it will compress some air but as the tank pressure rises more and more air will leak past the piston. If the reed valves on the valve plate are bent, warped or broken the same will happen. It's easy to check them for damage by removing the head but Emglow parts are getting harder and harder to find.
Apr 26, 2012 | Air Tools & Compressors
Hi, My Dewalt 3100 pressure washer pump wash leaking water from a check valve or overflow plug Do you know whats wrong?
Sep 08, 2011 | Dewalt DPH3100 Gas Pressure Washer
Dewalt D55168 air compressor runs until 95 psi and never stops. Pressure never goes above 95 psi. It use to stop around 140 psi.
Check for leaks all over the machine. Possibly the O ring on the drain valve is damaged. If the machine is oil-less, the big rubber O ring on the piston could be worn away.
When the machine is turned off can you hear air leaking from anywhere?
Mar 31, 2011 | Dewalt D55168 1.8 HP Wheeled Portable...
After removing the unloader valve and cleaning i
If you have pulsating usually you have at least one of the six check valves stuck open, so you're only running on two cylinders. You might have got some of your plumbers " grease" in the check valve. (Do you mean pipe dope?) three of the check valves shold be accessable from the outside of your pump but the other three are inside. You can get parts for your unit from www.pressure-washer-parts.com
Jul 19, 2010 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
My tilt/trim wont hold pressure in my 2006 60 hp(out of warranty) four stroke big foot. Lots of fluid still inside and no leaks visable or water. What could be the problem and the worst case re repair...
The problem is the seals or relief valve inside the pump or the cylinder seals. The fluid is suppose to stay where you pumped it. It is a closed system unless the outside and final seals leak on the cylinder. Then you would lose fluid.
You need to test the cylinders separately for bleed down. You would need a different source of fluid pressure. The pump can be hooked up to a fluid pressure gauge for testing.
If you do not want to deal with Marinas you may be able to get a Tractor place to test them. They deal with cylinders and pumps all the time. You can also save on replacement parts on the internet. Some of your parts may not be rebuildable. You can ask about the Labor beforehand.
Wish I could tell you a cost, but we really do not know what is broke or repairable.
Apr 06, 2010 | Boating
Dewalt 3700 Pressure Washer  Logo
244 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
