Question about Xerox Office Equipment & Supplies
Our F12 fax machine is making a terrible clicking noise - what's the problem?
    Scholar:
  • 141 Answers
Check to make sure toner and drum are completely seated. Remove them both, look for anything in the way, and replace them. Also check to see that the waste toner return path from the drum into the cartridge is clear and not packed full of toner.
Posted on Aug 05, 2009
  • Paul Anderson Aug 10, 2009
    Could also be a damaged fuser drive gear. 4 screws and a wire remove the fuser (wait to cool) and you can inspect the fuser drive gear. (Turn off, unplug, and wait to cool. Fuser runs at about 185 degrees F.
I have just replaced all the toner cartridges in my fax and it did a self clean. The machine was making these noises which sounded like the roller was getting stuck. It would then come up with a paper...
Open control panel on your personal computer where the printer is installed. Click the printer and faxes. Then right click on the icon of your printer and click properties. Then click the maintenance Click the Bottom Plate Cleaning. If the noise is still there after you clean the bottom Plate. Clean the Roller. And look inside your printer if there is something that blocking the roller.
Jun 24, 2011 | Brother IntelliFax-1860C Plain Paper...
How to de-install the FAX on my Lexmark all-in-one.
Scroll through the menus and set your fax to MANUAL MODE
Dec 28, 2008 | Lexmark X3480 All-In-One Printer
Recieving fax error
It could be a bad drum unit. If the drum doesnt turn smoothly it will make a clicking or grinding noise since it is gear driven. Take out the drum and turn the gear with your thumb. turm towards you. If difficult Thats it. It also could be a fuser gear. good luck Lawrence
Apr 22, 2008 | Brother IntelliFax-2820 Laser Fax
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Its clicking
Check and make sure that if you have something plugged into the fax/phone ports that it is installed correctly.  I had this noise when I accidentally put the usb cable into one of the ports.
Sep 15, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
129 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
