Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
My printer doesnt print mfc-240c - Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
    Genius:
  • 3,422 Answers
HI,
If the printer is sitting idle and there is no output, check the following:
  1. Make sure that the printer has power.
  2. Check that the printer is not out of paper, ink, or toner and that it is not in an error state.
  3. Verify that the printer hardware is working before continuing. Run a self-test (refer to the printer manual for instructions).
  4. Check the printer cable and make sure that it is attached properly to the port and the printer. Refer to your printer documentation.
  1. Make sure that the printer is enabled and accepting jobs. See ``Enabling and disabling printers'' and ``Accepting or rejecting print jobs''.
  2. Verify that the system has the port configured properly. See ``Port does not respond'' for more information.
Posted on Jul 02, 2009
SOURCE: paper jam in brother MFC 240C
the paper ripped at the corner in little pices and it is jamed in the printer how can I remove it
Posted on May 31, 2008
APremkumar
  • 564 Answers
SOURCE: Printer spits out blank page before printing
Check Your Ink Catridge. If the Catridge ink is full then try the following Steps.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Posted on Mar 02, 2009
eliza_syafik
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
clean unable 46,see troubleshooting and routine maintenance chapter in user guide.Plase help me to splve this problem.
Posted on Aug 12, 2009
  • 903 Answers
SOURCE: Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
Posted on Jun 04, 2010
Samyfam
  • 379 Answers
SOURCE: I get the following message
This is the Brother definition of error code 4F:
"The head drive voltage has dropped from the high to low level in an abnormally short period." or "The head drive voltage has not risen to the specified level within the specified period in the self-diagnosis"
Causes:
"Piezoelectric ceramic actuator defective (Cracks or rare short)"
or
"Main PCB defective"
No simple fix I'm afraid. You could contact a Brother repair agent but I expect they will want to charge you more than a new machine. Sorry.
Posted on Jul 12, 2010
Testimonial: "Thank you for the very detailed information and advice."
Mfc-240c prints lines in black
It may be your printer head that needs to be flashed. if you have not use the printer in a wile, the ink drys out and clog up the nozels. Do printer head cleaning, if not work, use paper towel with a little warm water, press the printer head on it.
Jan 03, 2014 | Brother MFC 240C All-In-One InkJet Printer
How can I set my MFC-240C printer to print from my computer
switch on the printer
1. install driver for mfc-240c
2. go to control panel in your computer
step to control panel
select START then control panel
3. select printer mfc-240c right click on it and then click on click on <Set as Default Printer>
4. right click again on it the select <properties> then select "print test page"
test page will printout on printer
5. now you can use mfc-240c as printer
Aug 19, 2010 | Brother MFC 240C All-In-One InkJet Printer
Can my brothers mfc 240c printer be used to print from more than 1 computer in my house wirelessly? how do I set this up?
The MFC-240C does not have a wireless interface, so you can't connect wirelessly directly to it. What you would have to do is set up a print server, which can be a standalone device or can be one of your computers, and then the other computers would print through that one connected computer.
Jun 26, 2010 | Brother MFC 240C All-In-One InkJet Printer
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
MFC-240C printer head repair
mY MFC-240C PRINTER IS NOT PRINTING WITH A MESSAGE " UNABLE TO PRINT SEE TROUBLESHOOTING
Nov 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
MFC 240C won't Print
have you tried to unplug the machine for twenty minutes then plug the machine back so that it will reboot?
Jan 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have windows vista and mybrother MFC-240C won't print, Says can't find printer?
first unplug ur usb cable from ur mfc-240c than deinstall all drivers of your printer
than reboot your system
than go here:
http://welcome.solutions.brother.com/bsc/public/midlink3.aspx?prod=mfc240c_all&lang=all&src=DOWNLOAD
click on your country flag and download the latest drivers for ur mfc-240c
install it
than when asked for ut plug in your usb cable from ur mfc-240c
the computer wil find your mfc-240c now whend asked for reboot than reboot
Dec 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Printing
it doesnt print black documents i have new colors
Jun 18, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
128 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
