Question about Canon PIXMA iP1800 InkJet Photo Printer
Erroe code 5100 pixma ip1800 - Canon PIXMA iP1800 InkJet Photo Printer
    President:
  • 2,306 Answers
5100 means either the carriage can't move properly from right to left, or the encoder strip behind the carriage assembly has grease or ink on it and needs to be wiped with a Q-tip. Sometimes the cleaning assembly on the right gets stuck in the up position and stops the carriage.
Posted on Jul 02, 2009
  • 2,404 Answers
Service error 5100 is a carriage home position error.
Turn off and unplug the printer from the power supply.
Remove any paper.
Buy a can of compressed air from an electronics shop or computer store. Use the compressed air (Not a vacuum!!!) to blast out any dust bunnies, paper particles and debris. (Don't do this with the cartridges removed as you're likely to fill the printhead with air!!)
Use isopropyl alcohol and a cotton swab (Qtip) to clean the plastic strip that runs the length of the guide rail (the metal rail that the cartridge carriage moves along), it may be contaminated with ink and debris.
Remove and reinsert the ink cartridges inside the cartridge carriage to ensure that they're connecting properly.
With the power off, carefully slide the print head (carriage) to the center of the guide rail. You should not have to force it! (There will be some light resistance but it should move quite easily by gently pushing on it with your finger.)
Close all the access doors, plug it back in, connect your USB cable and turn on the power.
As it runs through the initialization, the printer should sense that the carriage is out of position and automatically move it back to where it should be.
Good Luck.
Posted on Jul 03, 2009
How to solve 5100 error of canon pixma ip1880 series printer
Follow this procedure:
1. Enter Service Mode: Hold Power button and plug a power cord, then push Resume button twice and release all buttons.
2. Free Download from Internet: GeneralTools for Canon Pixma IP1880
3. Starting GeneralTools
4. CHANGE USB PORT change into PORT of your printer
5. click lock release
6. click ip1800
7. click device id
8. clear waste ink counter by clicking MAIN & PLATEN
9. Check EEPROM Box
10. Click EEPROM Dump
Power off printer and all done. Work again!
Jan 11, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My printer Canon PIXMA iP1800.with error 5100
Error 5100 is Cartridge Position Error. Try cleaning the whole strip where the cartridge is placed.
Jun 30, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Error 5100
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Jan 26, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My Pixma ip1980 service error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
Aug 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How can i solve the problem error 5001 of ip 1800 canon
5001 is not an error code but 5100 says that there is a paper scrap blocking the carriage, or grease on the encoder strip. The plastic strip behind the carriage assembly that runs all the way across the printer. Try first to clean the strip with a damp Q-tip just damp with water.
Jul 27, 2009 | Canon PIXMA iP1800 Printer
Error 5100
Error 5100 mean carriage error. Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
Jul 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA MP180 All-I-One It shows check printer 5100 erros
error 5100, this error appears and the problem is your cartridge, please double check your cartridge is connect properly and if it still have the errors change another cartridge, a new one...
Jun 22, 2009 | Canon PIXMA MP180 All-In-One InkJet...
How to correct error 5100 in canon pixima ip 1800 prnter
Hi You can Try
If you still look at this web then have a go
Error Code 5100
Solution 1:
Solution 2:
Sep 27, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printer error message
we still cant get it to print!!!!!!~ what is the matter!!!!!
Feb 25, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
252 people viewed this question
old marine
old marine
