Question about KitchenAid KUDK03ITBK Built-in Dishwasher
My superba dishwasher leaves a heavy film on the dishes. Sometimes it is black as though there was dirt in it. I use Cascade and electrosol jet dry. melody
  • 48 Answers
Hello, Over time dirt and grime both from the dishes and from the chemicals in the water build up in your dishwasher, you can resolve this by going to Wal-Mart, K-Mart or your local grocery store, their is a product that comes in a square bottle, it is in your dishwasher soap isle, you empty your dishwasher and take the cap off, tip it upside down inside your silverware tray, turn your hot water on in your sink and get it hot, then turn it off, turn on your dishwasher and run it from the pots and pans setting, it will clean the scum out of the dishwasher, I reccomend useing it every 30 days to keep your dishwasher clean and opperating efficiently, also you can remove the arm in the bottom of the dishwasher and clean that out by gripping the big ring at the base of the unit and turning it counter-clock wise and to clean it use a toothpick or q-tips to clean the debris from the holes in the arm, then install it back after you rinse the arm in the sink............hope this helps.........
Posted on Jul 24, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Dec 15, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Www.dishwasherfilter.com has a new product out for this reason. guarnateed to leave your dishes spotless or your money back. you will love the way they look.
Posted on Aug 22, 2009
  • 10,865 Answers
Hi Melody. The first thing I recommend is that you put two cups of vinegar into the empty dishwasher, set it on its longest and hottest cycle and run it. This will clean the dishwasher. That may be all you need to do.
However, your problem could be difficult to solve that that too. Use the vinegar and get back and let me know if that solves yout problem. I will hang in there with you to solve this annoying problem, I assure u. Joe
Posted on Jul 02, 2009
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
There is a white film left on dishes after the dishwasher is done. I use cascade detergent and jet dry rinse aid
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 23, 2011 | Dishwashers
It is 6 mos old and it leaves the dishes dirty and with a white film on everything. I used jet dry, cascade with no results. what would cause this? it has done this since day one. thanks
heatman101
Feb 23, 2011 | LG LDS4821BB 24 in Builtin Dishwasher
There is a film like residue on dishes after complete cycle has ran. I use cascade tablets and also have refilled the jet dry. It is on all dishes but the glasses and clear plastic show it the most.
heatman101
Dec 05, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My dishs and glasses have a foggy film on them all of a sudden, I use a powder dishwasher det and tried jet dry too, I can't use liquid cascade as I used it before and I do not have softwater and liquid...
Put two cups of vinegar into your machine and run the hottest and longest cycle you have this will clean the machine and solve the problem.
Jul 07, 2009 | Dishwashers
Hi, We have a new whirlpool dishwasher type no. 575-0. GU2275X TVQO. We have not been able to get clean dishes since purchase. Water is hot, everything seems to be operating smoothly. Use the...
I think I can help. We have the same dishwasher and we have very hard water. The dry powder detergents don't work well. We have found Cascade All in One Gel detergent works best and we use only a little; don't go beyond the first mark in the detergent dispenser, regardless what the instructions say. We have found using more of any detergent makes white film. Don't fill up the pre-wash side either. The Cascade All in One Gel does both at one time, so no need to put some in the pre-wash side. Also keep Jet Dry in the rinse dispenser and make sure it is set up higher, turn the arrow to 4. Try that and move up if needed. Next, we put half a cup of white vinegar in the dishwasher, just pour it in the bottom each time, right before we wash the dishes. This works GREAT! We used the white vinegar in on our former dishwasher of 9 years and never had any trouble with any film buildup. The vinegar cuts all the film and makes glasses look terrific.
If you are still are having trouble, cut out the Heated Dry at then end. The heat can cake hard water on your dishes. It may not dry the dishes as well, but it seems to stop any buildup. Using the vinegar though, we use the Heated Dry and still have no film buildup. So for us, we use a small amount of Cascade All in One Gel detergent (buy this basic gel, no added anything), 1/2 cup white vinegar poured in the bottom and Jet Dry in the rinse dispenser. We always have sparkling clean dishes with no hard water buildup. If you don't have real hard water, but just a little hard water, you might try decreasing the white vinegar to 1/4 cup and increase it if you start seeing the white film build back up. Also don't overload the dishwasher. Make sure there is space in-between each dish and have all plates face toward the center.
Make sure you turn your sink faucet on to as hot as you can get it and run the water until it is hot, then turn off the faucet and turn on the dishwasher. This helps to keep the dishwasher from running longer, which would mean more hard water swishing around longer if you don't heat the water, and you know what that means, plus the heating element has to work harder to get the temp up and that makes it burn out quicker. Once a month check your jet sprays, that turn around in your dishwasher, because the little holes can stop up with hard water gunk and this will cause film on your dishes to build up. Take a toothpick and crush the gunk in any holes and make it go out of the holes. Hope this helps you!
Apr 27, 2009 | Dishwashers
Our built-in maytag dishwasher is not cleaning dishes very well,
After you go out and buy/use a brand name detergent powder like Electrosol or Cascade (using less than the full dispenser cup each time), if problems continue, then have the heating element checked.
Very common for a film/food residue to remain when a dishwasher's heating element fails, even if the water heater temp is set to 120 degrees.
Good Luck!
Apr 01, 2009 | Dishwashers
Glasses are cloudy and rust spots on cuttlery
I had the same issue until I switched from Cascade to Electrosol. I still use the Cascade rinse solution in the door dispenser. Also use the heated dry option. The energy saving option seems to promote clouding.
Jan 10, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Inside of dishwasher not clean after running.
its a lime build up from the quality of your water.goto home depot/lowes or a supermarket and buy clr (calcium lime rust) remover.pour a cup in the dishwasher and run a full cycle.this should do the trick.
Jan 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
KitchenAid KUDK03ITBK Built-in Dishwasher Logo
268 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
