Question about Camping, Backpacking & Hiking
3Batteries stuck in large metal flashlight - Camping, Backpacking & Hiking
  • 19 Answers
Corrosion in light caused by acid leakage from Alkaline batteries. Batteries may have exploded in light to remove batteries, I usually use a solution containing dial liquid soap and water. Going heavier with the soap and gently slide the solution into the light, cover it and sit it upwards, wait 24 hours then slide the alkaline batteries out. Not sure if light will still work afterwards but, hey at least you'll get those batteries out. ;)
Posted on Aug 28, 2009
    Guru:
  • 1,326 Answers
Try tapping it on a piece of wood with the battery cover off. Its important to tap in as flat as possible to avoid denting the bottom(cover won't screw in if bent). Also try some WD40 grease spray inside the batt. housing. This is normally caused by a bent casing or batteries coroding and expanding inside the bat compartment.
Posted on Aug 09, 2009
Manual for ML1W2AAE
You can get the data sheet with the flashlight information at
digchip.com Just type in the flashlight model number.
Jun 18, 2014 | Energizer Metal LED Flashlight ML1W2AAE
CORROWDED BATTERIE STUCK IN FLASHLITE
Put on a pair of gloves. Then, using needle nose pliers grasp the battery and pull it out. If it's too far down to reach with needle nose, or if the corrosion has "welded" it to the inside of the flashlight, find a flat head screwdriver or stiff wire coat hanger or other tool/object that will reach and is stiff enough to pry the offending battery loose. Once it's broken free, turn it upside down and let the battery fall out on its own. The important thing now is, if you plan on using the flashlight again, cleaning out the inside thoroughly of all corrosive residue. This is particularly important on the metal battery/power contacts. A wire brush should suffice for the inside of the flashlight. Sand paper or file will work for the contacts. Attach to the tip of a screwdriver if you need to reach deep to get them clean. Baking soda will neutralize the battery acid. Finally, remember to recycle the offending battery not throw it out with the regular garbage.
Dec 12, 2013 | MagLite Mag-Lite& Flashlight
My flashlight will not turn off
This is what i did to make it work (by pure guesswork).
1. take the battery holder thing out.
2. see black arrow on side of battery holder, that needs to point toward the led end when you insert it.
3. Look at the end of the battery holder, at the end that will go in first when you insert it. On each end there is that silver metal circle that has some silver metal extensions that go straight across the bottom.
4. look into the flashlight toward the led end. See the green circular circuit board thing. You'll see that equally around that circular base, there are 4 little squares of metal right to the edge of the green base, equidistant around the green circle. Carefully insert the battery holder with the silver metal strip on the holder lined up so each end of that strip will touch one of the 4 little square metal things on the edge of the green circuit board. The goal is that when the battery holder is all the way in, the two metal extensions coming out from the little circular metal piece on the end of the battery holder will each touch one of the little square metal pieces on the green base.
5. Screw on the lid and click the end to turn on the light. I tried this two times and both times it worked. If it doesn't turn on you might want to try to reinsert it again and get it more carefully lined up.
Good luck.
Apr 28, 2013 | Emerson 9X Power LED Flashlight
What is the purpose of the screw at the base of the 95155 stanley 3 in 1 tripod flashlight
The pin has 2 magnets on it. When you hit the open button it pushes the pin down and releases the legs.
Aug 23, 2012 | Stanley 3in1 Tripod LED Flashlight 95155
I'm looking for a Bosch flashlight to fit my Bosch battery #7100.
Adding The particular FlashMax distinct powerful flashlights! They're torchlights to have really anxious about. They may be really potent. Remarkably resilient. And also are better as compared to some other flashlights which usually expense 5x the maximum amount of!
Potent: The trick powering these kinds of awesome flashlight torches : they will utilize DIRECTED emitters made simply by CREE, a head inside flashlight parts. The power for your requirements: large depth cross-bow supports it is possible to constantly count on when the necessity develops. Moreover : DIRECTED table lamps glow lighter and also utilize a smaller amount vitality!
Resilient: These kinds of flashlights hire a accurate machined dura-strength metal blend circumstance and possess recently been anodized regarding added rust level of resistance. The power for your requirements: a top efficiency system in which effortlessly withstands professional utilize damage just like simply no some other!
Apr 17, 2012 | Camping, Backpacking & Hiking
Have large metal flashlight with D batteries inside am unable to open end to replace batteries. Tried wd40 and it did not work
A possibility that the batteries have leaked a caused a galvanic corrosive issue, binding or fusing the end cap. See the manufactures instructions for removing and installing batteries.
Aug 25, 2011 | MagLite Mag-Lite& Flashlight
I accidentally drop my gerber firecracker flashlight, when I turn it on its not working any more.How can I detach the crown from bulb to fix the problem.Thanks for the help.
Hi I had the same problem. It seems that when I dropped it the back buttton got stucked, so what I did was to unscrew the back part (as if to replace the battery) and gave it kind of gave it a knock or hit it softly just to jiggle the button. Scre it back on and got it to work, Hope it works for you.
Jan 18, 2011 | Gerber Blades Gerber Firecracker LED...
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Metal nail fell into the garbage disposal.
Just above the motor par of your incinerator there should be 3 or 4 small bolts or srews that holds the main motor onto the waste chute TURN OFF THE POWER. Remove these bolts to seperate the motor and you should be able to remove the nail. Please, please make sure the power is off.
May 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Camping, Backpacking & Hiking Logo
308 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
