Question about Canon ZR45MC Mini DV Digital Camcorder
My computer has no firewire port
So, I've read that it's not possible to transfer videos from the miniDV to my computer without a firewire cable, but my problem is that I don't have a port for a firewire cable on my Acer netbook. Is there any other way? An adapter cable for USB? Something?
    Novelist:
  • 155 Answers
Unfortunately USB and Firewire use two completely different protocols for handling the data transfer, so it is not possible to just buy an adaptor that will change one to the other.
You can however buy fairly cheap plug in Firewire cards that will fit a notebook, providing you have an expansion socket (PCMCIA, CardBus, ExpressCard). Just try Googling '"Firewire for notebook"
Hope this helps!
Posted on Jul 02, 2009
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
Oct 17, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
Panasonic PV-DV953D video transfer to PC
Did you put the camcorder in the VCR mode and make sure it is turned on, so you can transfer the video?
Jul 30, 2008 | Panasonic PV-DV953 Mini DV Digital...
The transfer cord (1394) doesn't fit my new computer. Not sure what type of adaptor to buy.
Since the camcorder came with a 1394 cable (also know as a firewire cable) I'm guessing your camcorder is MiniDV is this correct? Your computer has USB ports standard, you usually have to get a Firewire adapter specifically. Is your computer a desktop or a laptop? If it is a laptop, there is not much you can do. If it is a desktop then you can get a firewire PCI card to put in that you can connect your camcorder to. Any more information you can provide would help me be able to give you a more accurate answer.
Aug 15, 2010 | JVC Video Cameras
How do i copy recorded video unto my computer
Add a firewire port to your computer and get that working. Then, using a firewire cable connected to the DV port of the camcorder (not USB), you will connect to the firewire port you just installed and import the video.
USB is used only for transferring stills from the memory card or maybe using the camcorder as a web-cam.
To get the video off the miniDV tape, you need to use firewire (IEEE1394a, i.Link... all the same thing).
Mar 19, 2010 | Panasonic NV-DS65 Mini DV Digital...
How do i transfer VIDEOS from the camera to the pc
to transfer video from your camcorder to your pc you will need a firewire cable (ieee 1394). only with this cable you will be able to transer video.
you will also need a firewire port on your pc.
if you don't have one then you can buy a firewire pci card.
see this for info and pictures
http://en.wikipedia.org/wiki/IEEE_1394_interface
Dec 16, 2009 | Panasonic PV-GS36 MiniDV Digital Camcorder
We would like to import footage from the Panasonic NV-GS 400 digital video camera onto a MAC - is this possible
Yes, you can transfer the videos from the Camcorder to the Mac Computer.
Connect the Camcorder to the Mac Computer using i.LINK/Firewire or USB cable.
I suggest that you use the i.LINK/Firewire cable to connect it to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer.
After connecting the Camcorder to the Mac Computer, open the iMovie Application to capture the Videos from the Camcorder and follow the on-screen instruction to complete the transfer of the videos.
Good Luck!!!!!!!!!!!!!
Nov 18, 2009 | Panasonic Cameras
Driver for DCR-HC28
It's not possible to transfer the videos from the Camcorder to the Vista running Computer using a USB connection.
The Camcorder uses the USB STREAMING function to transfer the videos to the Computer. The Vista doesn't support the USB STREAMING function.
However, you may transfer the videos from the Camcorder to the Computer using an i.LINK/FIREWIRE cable.
If your Computer has an i.LINK/FIREWIRE port on it you can connect the Camcorder to the Computer using the i.LINK/FIREWIRE cable.
The i.LINK port is a D shaped port labelled as DV, i, IEEE1394, Firewire.
If the i.LINK port on the Computer has 4 pins on it, then you can use a 4-pin to 4-pin i.LINK cable.
If the i.LINK port on the Computer has 6 pins on it, then you can use a 4-pin to 6-pin i.LINK cable.
The i.LINK port on the Sony Camcorder is a 4-pin i.LINK port.
I will forward a link to a page where you can get the steps to transfer the videos from the Camcorder to the Computer using the i.LINK connection.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Jun 15, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Firewire
Yes, you can capture camcorder video from a miniDV camcorder using a FireWire cable and video capture software. Your computer came pre-installed with Windows Movie Maker, or iMovie (if you are on a Mac).
FireWire, IEEE 1394 and iLink are all the same thing. There are 4 and 6 pin FireWire cords. My guess is that you need a 4pin to connect to your camcorder and a 6 pin to connect to your computer. But it all depends on what ports you have available.
You can get a FireWire cord for less than $10 at most computer electronics stores
Check out this FireWire guide for more information:
http://www.stashspace.com/video-editing/firewire-guide.stm
Mar 14, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Panasonic NV-GS70 lost cd installer
Hi, I purchsed Panasonic NV GS-70 in 2004 and facing the same problem in transferring videos to computer. I tried for firewire cable option as well, but the camcorder does not have a firewire port.
Can anyone suggest what kind of firewire cable to be used for it.
Feb 11, 2008 | Panasonic NV-GS70 Mini DV Digital...
Canon ZR45MC Mini DV Digital Camcorder Logo
1,629 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
